I have a 66 mustang and was interested in putting power windows in it. I know they make kits and everything but I was wondering if there was anyway I could use the motors from another car? Maybe something I could pick up at a junk yard? I can make brackets and everything? If this is possible and you have an idea how, too could you maybe give a little explanation. Thank you very much.
What i have is a spare front regulator and i popped the rivets off that holds the shaft that the crank handle slides on. The other end of that shaft has the gear that rolls the window up. Once that is removed, it is simply making up a bracket to mount the motor to the regulator. I bought a pair of fox body window motors on ebay for $10 and the teeth/gear mesh up nicely to the stock regulator. I have some pics of the stock 69/70 cougar power window regulators w/motors and am trying to mimic that same design. Hopefully i'll get around to that mod and mount the motor to the regulator so you guys can have a writeup on it
amnit: I'll be sure to do a writeup when i get it finished.
