power windows not working
blue87lx
175
heres the story guys.. ever since i got the car the windows would get stuck in place somtimes and after a whiel they would work again. now after n ew motor and paint i was putting the interior back in and i get to the window switchs and i put them in the driver side goes about 3/4 of the way stops like its binding up. i put it back down go and plug the passenger side in and turn the power on and the window shoots right up. what do you guys think is wrong? anything is helpful. bad ground maybe?
You state that it stops like it's binding up. When it stops, is the motor making any noise like it's trying to get the window up and it can't or does it stop all noise like it lost power? If it's the latter, when it does it again, I would get a multi meter and start checking voltage. I would start at the switch to rule it out and then move from there. Because yea a bad ground could be a problem.
Just my 2 cents
Remove the door panel and window and see if the track still goes up/down. Look at the tracks and see if you can see any bent track. If not, and you checked the switch, you might as well replace the regulator. I have replaced two regulators and one window motor. Boy are they fun!!!!! BTW, don't replace the motor, replace the whole regulator/motor combo or you will have problems galore. It is about $180 bucks for a regulator BTW.
Let us know if you need further help
I had a 91 Mustang similar problem...I had a bad power window switch on the passenger side that made the drivers side act up. My windows would go down and up really slow too...I squirted all the tracks,arms, and guides with chain lube from my dirtbike and they went up perfectly...easy enough for me..try that out.
