- Sep 17, 2004
- 67
- 0
- 0
Hey all,
I installed an aftermarket alternator tonight and I had some questions. The alternator is made by OE Plus ( www.oeplus.com ) and it's a 100 amp alt. I bought the PA Performance Power Wire Upgrade Kit as well. We tried to find a place for the Power Wire Kit to hook to the alternator but it was just a clip sort of.. there wasn't a place to hook into the alternator. Now i'm almost positive that you have to upgrade the power wire when you upgrade the alt. amperage. I was just confused as to why the PA Performance kit wouldn't work.. the only reason I could think of was that the alternator wasn't made by PA Performance. The Alternator I bought came with a paper that said "Every time a Ford IAR alternator is replaced, a new alternator-to-wiring harness plug must be used." Is that like the same thing as the Power Wire Kit? I'm just confused as to where to connect the Power wire on the alternator... If the alternator will be ok without the power wire upgrade kit.. then i have less worrying to do. I just wanna make sure everything is safe- if anyone can tell me where to hook the power wire to the alternator.. or if it's not even needed, that would be great, thanks!
