PowerDyne?
  • Thread starter Thread starter 352Ford2
  • Start date Start date Nov 3, 2005
352Ford2
393
Seattle,WA
Nov 3, 2005
  • Nov 3, 2005
Who is running powerdyne superchargers and what do they think of them?
what else needed to install other than what came in the kit?
anyone try to intercool one?
ss93cobra
1,422
Wilmington NC
Nov 3, 2005
  • Nov 3, 2005
You might have better luck in the poweradders/superchargers forum. I've got a Powerdyne on mine and I've had no issues with it. Spools up quickly and quietly, no need to tap the oil pan for plumbing, and simple to install. The earlier Powerdyne's had issues with the internal belt breaking, but that issue has been resolved and as long as you don't try to put a larger pulley on a smaller head unit (for example, 11lb pulley on a 6lb blower) you'll be fine. Necessary addtions would include :bypass valve, ignition system, adjustable fuel pressure regulator, larger fuel pump, cooler & spark plugs. Can't help you on the intercooler question though.....
Paul Perreca
1,085
  • Nov 3, 2005
wouldn't that be putting on a smaller pulley? i thought to increase the psi u would put on a smaller pulley....
in addition to his list, fuel injectors...
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Nov 3, 2005
  • Nov 3, 2005
Depends on wether you are talking about the drive pully or the driven pully.
Smaller pully on SC itself = more boost.
Smaller pully on crank = less boost.
ss93cobra
1,422
Wilmington NC
Nov 4, 2005
  • Nov 4, 2005
please excuse my verbage. Yes indeed, a larger lb. pulley would be a smaller pulley. Hey, I'm from IN, you're lucky I knew what Powerdyne meant....
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Nov 4, 2005
  • Nov 4, 2005
If you are purchasing new, just get the vortech SC kit, the price is tough to beat. Car will make more power. For the same cost.
just4bob50
504
Pa.
Nov 4, 2005
  • Nov 4, 2005
All powerdyne BD- 11a supercharger heads are the same. weather it is a 6psi pulley or 11psi pulley. The BD-11a has a maximum impeller speed of about 44000 rpms before you reach the limits of the head unit. I have a 6psi pulley on mine and with the 4" power pipe i made it makes 8lbs of boost at 6000 rpms. I am sending it back to powerdyne to put a 9psi pulley on. if i have them do it i will keep the full warranty. check my sig for mods and times
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
Supercharger and What else do I need? 1990 Saleen Vert 5spd
  • AlbertaGolfer68
  • Aug 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
General karthief
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
H
Drivetrain 6R80 to t56 swap
  • Holymoses
  • Apr 25, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
AeroCoupe
