Powerheads.....
  • Thread starter Thread starter 99FiveOh
  • Start date Start date Apr 7, 2011
99FiveOh
2,051
20
99
J-Ville, FL
Apr 7, 2011
  • Apr 7, 2011
I remember flipping through old 5.0 Mustang and MM&FF magazines and seeing these heads for sale. I think they started off at 695.00 per set. Now I decided to check them out on the web and went to this link: Power Heads - Performance Engineering
almost 900 bucks for a pair of stockish iron heads??! Unbelievable. Don't these people know that you can get some pretty nice aluminum heads nowadays for just a few more bucks? Hell a pair of Edelbrock E streets can be had for a mere 939.00 give or take a few $.
I thought these guys were all about saving some cash.
sn-95matt5-0
170
  • Apr 7, 2011
Wow did i read that right? That 900 bucks is if you send them your stock heads, a 200 dollar core charge will other wise be added. So that brings it up to 1100 for a pair of ported stocks. And in there shortblocks its $2850 for a 351w. You can buy a 408 from chp for $2662?
JJ95GTID
1,141
Phoenix, AZ
Apr 7, 2011
  • Apr 7, 2011
For starters those are far from "stockish" heads.
Larger valves, CNC ported, valve springs for .530" lift cams, etc.
I remember looking at their heads 9 years ago and they were $695 then and stayed that price up until a about year or so ago.
I imagine that they have gone up in price since then.
Used be a guy with the username Thumper doing some similar things with stock E7TE heads too.
I bet you can't get Thumper heads for $695 today either.
Back in 2004 I was lucky enough to be in the market for heads when FRPP were removing all the Y303 aluminum heads from longblocks to put the then new Z-heads on them.
They called them take-off heads. Since they were bolted down they couldn't sell them as new heads.
$724/pair to my door! Back then I was comparing the Power and Thumper $695 heads to these Y303 aluminum take-off heads and couldn't resist the great deal.
Yeah, they are the lowest performing aluminum head you could buy but they work very well for me.
99FiveOh
2,051
20
99
J-Ville, FL
Apr 7, 2011
  • Apr 7, 2011
nope, thumper still charging the same as he has for many years: Thumper of Orange Park
I know CNC machines cost $$, but no way in hell in this economy I'm paying 900 bucks for a set of reworked stock iron heads when I can get some Edelbrock aluminums for 40 bucks more! That's a bunch of weight off the nose of my car and the benefits of an aluminum head.
JJ95GTID
1,141
Phoenix, AZ
Apr 7, 2011
  • Apr 7, 2011
Yep, I can't argue that at all. You could probably find a nicer set of aluminums used for even less $$$.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 7, 2011
  • Apr 7, 2011
Thumper heads aren't a bad deal. Honestly that's about what a machinest would charge you to rebuild heads back to stock. E-streets are garbage. You need to replace a bunch of valve train parts on them as soon as you get them.
Kurt
99FiveOh
2,051
20
99
J-Ville, FL
Apr 7, 2011
  • Apr 7, 2011
So Edelbrock tries to fight off the Chinese knock offs and ends up with the same garbage they're trying to discredit! Classic! At least some Americans got a paycheck because of the E street heads, so I guess it's a better deal.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 7, 2011
  • Apr 7, 2011
Yeah, that's what someone was saying on Corral. Edelbrock built the E-streets specifically to compete with Chinese knock offs. They don't recommend running The E-streets with a roller cam, and even then only with extremely low lift.
Kurt
9
94gt5.o
177
ferndale WA
Apr 8, 2011
  • Apr 8, 2011
While I can not say anything negative about those Holley heads, I will say you made an excellent choice over the E-streets. Not to hijack your thread or anything, here is my results from those heads, particularly with the valvetrain. WARNING: Edelbrock E-Street Heads - Ford Mustang Forums : Corral.net Mustang Forum The casting of the E-streets are a bit rough; but the flow numbers are comparable with AFR 165's, TW 170cc, etc.
Im so glad i dident go with these.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
TTSaleen's Foxbody Project
  • TTSaleen
  • Apr 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 17, 2026
TTSaleen
Progress Thread 1989 LX 5.0 convertible - mild project
  • Scott_S
  • Aug 18, 2025
  • 5 6 7
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 15, 2026
DadLife0724
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
