  • SN95 4.6L Mustang Tech
ppl with vt stage 2 cams-INPUT NEEDED
  • Thread starter Thread starter blckstng96
  • Start date Start date Oct 8, 2007
blckstng96
208
  • Oct 8, 2007
im just wondering what your call pulls to rpm wise with these cams.list what you have for heads and stuff.my car doesnt seem to be pulling up to where it should be with my setup
5.0 stroker
fox lake stage 2 heads with manley hi rev springs and titanium retainers
vt stage 2 n/a cams
bbk upper with 75mm throttle body
jlt
lightning maf
24lb injectors
that should be adequate enough to give an idea.
thanks in advance
Scorcher2005
883
South Carolina
Oct 8, 2007
  • Oct 8, 2007
Have you put it on a dyno to see where your peak HP rpm is? You have any type of tune on that or running stock settings? You put the cams in right? Many factors to consider here...
blckstng96
208
  • Oct 9, 2007
it is tuned and you can see on the graph from the datalogging that the power is pretty much done at 6k,you dont need a dyno to tell you. i do also have a a stock lower intake and im thinkin the cams are not enough for the motor since it has been bored and stroked.
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Fox 89’ GT 331 stroker, Trickflow upper/lower, TF#3 Cam, stuffed with forged goodies.
  • 08GT500
  • Nov 6, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 6, 2025
08GT500
Y
Dyno Comparison for TFS 44cc Ported Heads vs PI Ported Heads with same VT Stage 2 Cams
  • Yel2002GTAuto
  • Oct 13, 2022
10K
SN95 4.6L Mustang Tech Jan 29, 2023
Yel2002GTAuto
Y
C
HiTech Stage 2’s in NPI heads?
  • ClayBelt
  • Oct 11, 2021
SN95 4.6L Mustang Tech Oct 11, 2021
ClayBelt
C
2000 GT dies once warmed up
  • bigred90gt
  • Jun 21, 2022
1996 - 2004 SN95 Mustang -General/Talk- Sep 18, 2022
My Copilot Zip
