Pre-geared Differentials??
  • Thread starter Thread starter Na5.0HO
  • Start date Start date May 19, 2004
N
Na5.0HO
342
Michigan
May 19, 2004
  • May 19, 2004
Hey guys,
So, it's time for a new rear end... 2.73s suck and my old diff gives me nothing but one wheel peels.
Question is, i believe they make 9" differentials which can come with aftermarket gears already installed. So, what about 8.8"???
Does any company make an aftermarket differential for an 8.8" with aftermarket gears already installed???
Example: An Eaton differential with 4.10 gear already installed.. like a package deal??
Thanx for any positive feedback either way,
Jason
TT91
1,536
Paramus, NJ
May 19, 2004
  • May 19, 2004
They dont sell kits like that already bolted together if thats what your asking. Not even in 9in. Gears are tricky, they need to be shimmed properly in order to obtain the proper backlash.The 4:10 gear you mentioned as an example is a 2 peice gear. The pinion gear, which is bolted to the driveshaft throough the axle housing, and then the Ring gear, which is spun by the pinion gear, and is bolted onto the differential.
N
Na5.0HO
342
Michigan
May 19, 2004
  • May 19, 2004
Ok, worth a shot... thanx for the feedback
The Shape
2,224
East ARKANSAS Delta
May 19, 2004
  • May 19, 2004
Actually I have a catalog from a place called Racer Walsh. I think the site is just www.RacerWalsh.com i'm not sure I am at work and don't have the catalog handy. Anyway they have complete 8.8 packages with axles for around $750.00. Have no idea if the gears and everything are already installed or not.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Drivetrain 8.8 trac lok spider gears..
  • rednotch
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 28, 2025
rednotch
