I purchased a 92GT with a T-5, while I was home on my mid-deployment leave. It has approx 189,000 miles on it (carfax said it rolled over about 10 years ago from registration records). It has had a few updates from the previous owners. The stock exhaust had been removed, and an off-road xpipe was installed all it has is dumped flowmasters. With the loud exhaust it is hard to tell if it has any engine issues, but it drove magnificently and I took an '10 Camaro SS by surprise one late night in Sept on I635
The transmission exhibited some issues in 3-5th gears. And my brother took it to Dallas Mustang to get a new T-5 installed. They also checked/replaced the rear main and I had a new heavier duty clutch installed.
I bought the car and intend to drive it back to Alaska where I am stationed. I am setting aside money to get the car ready to make the drive without issues I hope.
It has been a while since I've owned an older model car and have to re-introduce myself to it's older tech compared to the newer cars of today.
I plan on doing the normal plugs/wires/distributor cap replacement, along with all the filters/oil. The car is a project to keep me busy when there is snow on the ground for 6months in alaska.
I wont be home till next spring so I have lots of time to research what all I should definitely do, as well as recommendations from fellow Mustang owners here.
Checklist for replacement:
Oil Filter
Air Filter (CAI type)
Fuel filter?
Drain/bleed brake system?
Spark plugs/wires/distributer cap/coil (any recommendations or go with FRPP?)
drain/flush radiator
check timing
remove mufflers from x-pipe and purchase a new GT exhaust
As Needed:
replace front rotors as needed/machine rear drums
This is my first Mustang (my brother had an older early 70 model coupe), and I am extremely excited to be driving, and working on it.
Oil Filter
Fuel filter?
check timing
As Needed:
