pressing out ball joint?
AUBURN1111
560
20
49
Mobile, AL
Has anyone used one of those giant C-clamp ball joint presses to remove and intall a ball joint. Mine needs replacing and several people have mentioned that you have to take the control arm off and and take it to a machine shop. Let me know if the C-clamp press is worth it.
In some cases it's easier to just buy a new set of control arms, i think they were stock on 93's they have the clear ball joint dust cover.
That's what i did.
yep. the C clamp route works well. i had a shop do it anyhow, since i was getting bushings pressed in and out.
those things do work well though. as Todd mentioned, AZ loans them out.
good luck.
ball joint half done
So I used the giant C-clamp press and it works very well and to confirm what others have told me the 94 ball joints do press into the older A-arms which is nice for me cause Im using newer style spindle for the 5 lug conversion
