Primer
  • Thread starter Thread starter 67LimeGreen
  • Start date Start date Dec 2, 2009
67LimeGreen
North Carolina
Dec 2, 2009
  • Dec 2, 2009
I am getting ready to sand down my 67 mustang to prime it, I am going to be doing all the paint and body work myself. I had originally planned on sanding down to metal and then putting down Por15, putting the Por15 Tiecoat primer on top of that, and then the topcoat, mainly for rust prevention for the future. However, I contacted Por15 and they said its not really meant to do a whole car, just under carriage, floor boards, etc...So my question is what is the best primer to use or rust preventative? I will get some pics up in a couple days of the car, there is next to no rust on the outside of the car, I am pretty lucky in that aspect, and I will be sanding the entire car down to metal and removing most rust anyways, I just dont wont to put on some cheap primer and run in to problems a few years down the road.
rusty428cj
943
267
104
Port Richey Fl
Dec 2, 2009
  • Dec 2, 2009
I only use SPI primers in my shop. I have sprayed their epoxy and it has been outside for over 3 years with no problems. In the engine compartment that is all you have to use to get a semi gloss look. Check them out at www.southernpolyurethanes.com
V
voodooRunner
39
  • Dec 2, 2009
If you are sanding down to bare metal I believe you should use an acid etch which will bite into the surface and neutralize any corrosion that you can't see, followed by a high build primer.
chris66dad
167
Benicia California
Dec 2, 2009
  • Dec 2, 2009
Another recommendation for SPI epoxy and high build primer.
Acid etch is not recommended or needed with SPI epoxy. It is also about half the price of the other brands.
Here is a very interesting forum for professional painters on how most other epoxy primers can be wiped off with thinner and SPI drys hard and will not be affected by paint thinner or solvents:
Epoxy softens with thinner
SPI epoxy
Self Etching Primer
Here is our backyard primer paint job: Painting it ourselves
Good Luck and BE Safe
Ron
V
voodooRunner
39
  • Dec 3, 2009
Unless you are media blasting or chemical-dipping your car, wouldn't an acid etch or other form of metal prep be beneficial for neutralizing leftover/unseen rust before priming?
rusty428cj
943
267
104
Port Richey Fl
Dec 3, 2009
  • Dec 3, 2009
Do not use any metal prep because that will be your weak link unless all of it is removed before you epoxy prime. All you need to use is SPI epoxy and you can't beat the price for such a quality product.
NasaGT
1,993
Virginia
Dec 3, 2009
  • Dec 3, 2009
Another vote for Epoxy primer. I use Dupont, their epoxy primer is like armor. I'm sure other brands are the same. Stick with one manufacturer for all of your paints though, epoxy primer, high build primer, sealer, base and clear.
65Rob
Victoria, BC, Canada
Dec 3, 2009
  • Dec 3, 2009
You can use either etching primer or epoxy primer, most everybody these days uses epoxy primer, it has zinc in it which inhibits rust. As far as which brand you choose, I would stick with a reputable name, Dupont, PPG, etc., I have heard good things about SPI and I believe their price is very reasonable.
rusty428cj
943
267
104
Port Richey Fl
Dec 3, 2009
  • Dec 3, 2009
You do not have to stick with one brand if you use quality products. For the last 5 years I have been using SPI epoxy. SPI urethane primer, Diamont base with SPI reducer and SPI clear with no problems.
sparx
369
#10
  • Dec 4, 2009
  • #10
Who sells SPI products, I ran it out on Goggle didn't find vendors.
sparx
Platonic Solid
1,960
CT-USA
Dec 4, 2009
#11
  • Dec 4, 2009
  • #11
Hmmm, that red, white and blue Mustang on SPI's Techcover looks familiar
rusty428cj
943
267
104
Port Richey Fl
Dec 4, 2009
#12
  • Dec 4, 2009
  • #12
sparx
You can buy direct from SPI www.southernpolyurethanes.com
sparx
369
#13
  • Dec 4, 2009
  • #13
Thanks
Rust under side window weatherstrip
  • swe13
  • Jun 5, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 5, 2025
swe13
Paint and Body What kind of primer for bare metal rust repair?
  • AnthonyA1234
  • May 24, 2024
Fox 5.0 Mustang Tech May 24, 2024
General karthief
Paint and Body Strut tower beginning to break apart, how long do I have ?
  • AnthonyA1234
  • Apr 4, 2025
2K
Fox 5.0 Mustang Tech Apr 21, 2025
AnthonyA1234
Engine Strange Noise
  • burntokita
  • May 8, 2026
Fox 5.0 Mustang Tech May 11, 2026
keel
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
