Pro 5.0 install tools?
  • Thread starter Thread starter Matts89Notch
  • Start date Start date Feb 9, 2007
M
Matts89Notch
62
  • Feb 9, 2007
What tools are needed to R&R the factory unit with a pro 5.0 sts...I did a search and could find nothing...
HISSIN50
34
129
Feb 9, 2007
  • Feb 9, 2007
You need to remove four 8 or 10 mm bolts and four 13 mm bolts IIRC.
Getting the front two dust boot bolts (the smaller ones) off with the console installed can be a pain. A ratcheting box end wrench worked well for me.
It's been years since I did this, so my bolt-size info might be off.
Good luck.
M
MustangOwner
Banned
Dec 13, 2006
160
  • Feb 9, 2007
Well im installing my hurst shifter right now, its all easy but removing the insulator or whatever it is. it has 4 8mm bolts. You gotta get a ignition wrench or just bend a 8mm wrench so it works. I bent mine. And you need sealer for the new shifter. Thats it
vikingpower
656
CWU Ellensburg, WA
Feb 10, 2007
  • Feb 10, 2007
so easy a caveman can do it
tording
164
Hampton, VA
Feb 10, 2007
  • Feb 10, 2007
What if I said "so easy a therapist can do it".
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Brakes 80 Mustang 4.2 rear chassis brake line for 5 lug conversion!
  • StangPowerLSX510
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 9, 2026
limp
Idler pulley as substitute for Power Steering Pump ?
  • Bhenders
  • Jul 15, 2026
  • Other Auto Tech
Other Auto Tech Jul 16, 2026
LILCBRA
M
a Pro-M EFI system
  • maximilian macdoanald
  • Feb 6, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 5, 2026
X-cam34
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
