Pro 5.0 or steeda tri ax? and a dumb?
seany425
90
looking to get a new shifter read the reviews and both sounded like good products and im guessing it comes down to personal preference. So guys what do you think. keep in mind, i dont want a real short shifter i figure ill have to buy a longer handle, but which one is better? also i can use the factory boot, mach 1 knob, and everything with the new shifter right?
I prefer a pro 5.0 myself. I have run two pro 5.0s in my cobra and I have a tri-ax with a pro 5.0 handle in my 88. I personally just like the solid feel of the pro 5.0 and short handle. Since you want a longer handle you might want to look into the tri-ax then.
Yes your boot and shift knob will work with an aftermarket shifter.
We've got both - and we wish we would have bought another Pro-50 rather than the Tri-Ax. It's not bad, much better than stock, but not as precise and race like as the Pro-50.
I've also used the Tri -Ax handle on the Pro-50...if you need the extra length and angle that this provides, spend an extra $30 and get the Tri-Ax handle, but the difference is minimal, IMO. I've swapped handles back and forth several times...it's a simple 5-10 min swapout.
