Pro 5.0 Shifter Question
I just installed my new Pro 5.0 shifter in my 04 GT and when I put the car in gear it feels like it's loose and doesn't stay in place, like it wants to fall out of gear. Is this normal? I followed the directions carefully and made sure that everything was tight. Any suggestions or help would be appreciated. Thanks.
I set the stop bolts according to the instructions. I put it in 2nd gear, adjusted the bolt so it touched the shifter, then backed it off about 1 turn and tightened the nut. Then put in in 1st gear and did the same with the bolt. Let me know if this sounds right...thanks.
