im interested in the pro 5.0 shifter but the last thing i want is a smaller stickshift is there anyway i can buy extra to make it about the size of the stock stick shift ? dont want to lean forward going into 3rd
Pro 5.0 also makes a forged steel handle that is identicle height and bend to the stock one. If you'd like it shorter than stock, but not as short as the famous Pro5.0 handle, get your Pro5.0 from http://www.konaracing.com/ with their lever on it.
Doesn't the stock handle bolt right up to the pro 5.0's? I have a Pro 5.0 but i never tried it because i like the smaller stick but i could swear i read the stock handle will bolt to it....or is that only the newer pro 5.0?
No. Well, yes, with an adaptor. The holes in the lever are too big. Well, they aren't, if you retain the stock rubber vibration isolator- which kindof defeats 90% of the benefit gleaned from an aftermarket shifter. For the money, you may as well get the Forged stock style lever from Pro5.0. Looks like stock, reachable like stock, shifts like a PowerTower.
