pro 5.0
  • Thread starter Thread starter txgunrunner
  • Start date Start date May 9, 2005
txgunrunner
68
houston, tx
May 9, 2005
  • May 9, 2005
installed a pro 5.0 shifter today but lost the instructions. when adjusting the stop bolts, how much should i back off the nut after it touches the shifter handle. thanks
NKau
1,346
Jefferson, WI
May 9, 2005
  • May 9, 2005
The shifter should hit the stop, but then be slightly off the stop when it's at rest with your hand off it........so just back it off a little bit.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
May 9, 2005
  • May 9, 2005
Back it off one full-turn when the car is in gear and when it is resting against the stop. That is when you back it off a turn. If the car pops out of gear in 4th for example...pop the cover back off and back the nut another half turn until the popping out stops.
Good Luck
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
