pro kit drop
It would be smart to get an alignment, you should not need camber plates. However, the stock strut mounts are weak and can fail. The rubber blows out and they make a popping noise. If you have enough in the budget, replace them with something like the Steeda HD Strut mount or the GT500 unit. If you are replacing the front struts or springs, then is the best time to replace the mounts.
