Nate
If your Q is directed to me then my answer is our pcm in our car does not respond to mods as well as the Fox body pcm does in the Fox body cars.
A fact I don't deny but that fact does not make the older pcm retrofit in our car the only or best solution. It was an option that at one time was the only option/solution but nowadays we have more options. The retrofit can be good for some combos but it can also become obsolete if you go far enough with your quest for power or drivability issues become unbearable.
I've just about gotten burned out on the retrofit pcm/our pcm's are a piece of junk statements and I think I'm wasting my time with these kind of threads trying to show peeps info that can be found with ease on this site, Corral, Tuner sites, etc. It has become obvious to me that I'm not helping anyone with this subject so for the LAST time..............................
If you want MAX power & BEST possible drivability on a STREET NA H/C/I combo with complete supporting mods...............
Fox Stang...............will need custom tune
94-95 Stang............will need custom tune
Both pcm's can be tuned with great results equally well by a KNOWLEDGEABLE tuner.
My direct answer to your Q is YES our pcm's will work just fine with mods but at SOME POINT it will need help from a custom tune.
I'm done now
Later
Grady
