does anyone else with a 94-95 5.0 have this kind of problem? at idol unless i have it turned up over 1000, sounds like its going to die and the motor sounds like its running out of gas. i was told because of the way my cold air goes the air doesnt flow through the sensor correctly, could this be it? causing the computer to read things incorrectly and not put enough fuel in.
i was also told that i could turn the pro m and make it so the air flows from the filter around the bend right into the sensor, but if i tried to do that the bolts dont line up so i would be forced to cut, turn and reweld things. has anyone one heard or anything about something like this?
Have you ever thought about getting your current one tuned?
