Problem w/ Starting.
Venom351R
4,548
41
98
MAINE
I bought a 93 Hatch this past Aug and did not drive it much since then. Just have it in the garage until I can decide the exact route Im going to take w/ the car. Here is the issue Im having w/ it (besides a huge ass oil leak)
When I first bought the car the guy I bought it from said you would have to disconnect the starter wire from the solenoid or once the car fired up it would continue to try to start. The car in fact did this but after driving it from N.J back to ME it would no longer do it. I just connected the starter wire to the solenoid and it would start up fine. The car sat for a little while at the end of the summer/early fall and I went to start it up to pull it out of the garage and it reverted back to its old problem of continuing to try to start itself after it was running. Before once it fired up I cold just disconnect the starter wire from the solenoid and it was fine and would run w/ no issues but this time it was bolted on b/c I figured it just stopped doing it. Needless to say something burnt out b/c it would no longer turn over and I could smell that something burnt up. Any ideas on if it was the solenoid or the starter and any ideas on what was causing this problem in the first place?
The test path for no crank starter problems isn't exactly specific to your problem, but the diagrams will be useful. Most of the time when a starter keeps running after you release the key, the starter solenoid has welded the contacts. To isolate this, disconnect the small red wire that is stuck on a stud on the starter solenoid. If the starter quits running, you have ignition switch problems. If it keeps running, the solenoid contatcts have welded themselves together. Smack the backside of the solenoid with a hammer and sometimes it will unstick the contacts.
The contacts weld themselves for a number of different reasons. Bad solenoid, bad ground, or bad wiring/connections. You get to inspect everything, and that takes time. The battery cables with the two bolt battery terminal repair ends are a definite no no. They will corrode and make bad connections. The acid will sometimes find its way up under the insulation and make corrosion inside the cable, so look for swells and breaks in the insulation.
Here's a checklist:
Since some of the tests will bypass the safety interlocks, make sure that the car is in neutral and the parking brake is set. Becoming a pancake isn’t part of the repair process…
Check battery, terminal connections, ground, starter relay switch (also known as solenoid) and starter in that order.
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection: more than .5 volts across a connection indicates a problem.
See http://www.fluke.com/application_notes/automotive/circuit.asp?AGID=1&SID=103 for help
1.) Will the car start if it is jumped? Then clean battery terminals and check battery.
2.) Check the battery to engine block ground, and the ground behind the engine to the firewall.
3.) Jump the big terminals on the starter relay next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
4.) Then pull the small push on connector (red wire) off the starter relay (Looks like it is stuck on a screw). Then jump between the screw and the terminal that is connected to the battery. If it starts, the relay is good and your problem is in the rest of the circuit.
5.) Remember to check the ignition switch, neutral safety switch on auto trans and the clutch safety switch on manual trans cars. If they are good, then you have wiring problems.
Typical start circuit...
Diagram courtesy of Tmoss &Stang&2birds
attachment.php
See http://www.autozone.com/images/cds/gif/large/0900823d80195963.gif for 88-90 year cars .OR see http://www.autozone.com/images/cds/gif/large/0900823d80195964.gif for 91-93 year cars. See http://www.autozone.com/servlet/UiB..._us/0900823d/80/1d/db/3c/0900823d801ddb3c.jsp for 94-95 model cars.
6.) The starter may be hung, loosen up the bolts that hold it on, and give it a good whack with a big hammer. Tighten up the bolts and try again.
7.) If that doesn't work, use a jumper cable from the positive lead on the battery direct to the starter post where the big wire from the relay connects. If it cranks then, it is the power wire from the relay gone bad. This will be hard to do, since there isn't much room to do it.
8.) Pull the starter and take it to Autozone or Pep Boys and have them test it. Starter fails test, then replace it. If you got this far, the starter is probably bad.
