problem with bbk longtubes and steering shaft
That sounds like a smart thing to check on. If that dont cut it, then mark it carefully where it rubs and ding the tube in a little until it clears. I have watched my dad heat the tube with a torch and "squash" it a bit with a big pair of channel locks. A small dent wont hurt anything. I would be pissed if they are coated and send them back, marked where they dont fit.
had the same problem at first............. motor mouts were shot and the engine was mounted low in the craddle and twisted. Got new mounts and raised it up in the cradle until it didnt hit and bolted it up why waste money on a steering shaft?
I took the steering column back out (loose) pushed it through the firewall abit more, put in the bolt on the shaft, tighnened it up and then put the steering column back, still rubs a little but not enough to complain about, thank you guys, I just couldn't get it in with the steering column in......
