problem with clutch cable help please
  • Thread starter Thread starter rudy herrera
  • Start date Start date Apr 21, 2011
R
rudy herrera
110
Apr 21, 2011
  • Apr 21, 2011
i recently got a rebuild tranny and a new cluth i have a stiffer cluth it ripped my cltuth cable on the test frive i replaced it with a auto zone one and it triped on the way back from the shop and then i got oem from my friends recked mustang and thaT LASTED TO WEEKS well to day i was going to waork and know the clutch engages all the way at the bottom like when its about to rip i think the cable got stretched .. wat do i do do i need to adjust it or i need to buy a new one i dnt want to get adjustable quadrent and cable i dnt have money for that know i need the car to get to work i just want something thaT wont break all the time
help please this is realy iritated i need help
f8tlfiveo
My wife likes my spool and blow-off valve.
Aug 8, 2007
1,585
102
64
Lancaster, PA
Apr 21, 2011
  • Apr 21, 2011
I have an adjustable cable and aftermarket quadrant with no firewall adjuster. The cable adjusts on the trans side with 2 nuts. So far I haven't had any issues with it. The stock quadrant and cable should work fine if it is in good condition.
cobra1923
68
Baltimore
Apr 21, 2011
  • Apr 21, 2011
New OEM cable with stock quadrant if it's in working order... otherwise get a cheap quadrant and firewall adj - but still with OEM cable
wythors
Get off my lawn!!!
2,277
35
69
C Addle
Apr 21, 2011
  • Apr 21, 2011
If you're breaking that many clutch cables, there's something wrong with the clutch install, not the cables. My bet would be that the bearing retainer that the throwout bearing rides on is galled up and not allowing the bearing to slide freely, or whoever installed it didn't lube it before they buttoned it up. Either way, go to the Ford dealer and get yourself a factory cable. That is the only one worth a hill of beans.
BYRDPE
1,556
Memphis,Tn.
Apr 21, 2011
  • Apr 21, 2011
ditto....gonna need to drop the tranny to see whats amiss.
Beasty306GT
671
Oxford,Mass
Apr 21, 2011
  • Apr 21, 2011
pull the cover off the clutch cable fork and check the throwout bearing...use a stock oem ford cable if your gonan replace it it comes with a new fork
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
2003 gt, clutch pedal stiffness.
  • 2003 mustang gt modded
  • Feb 15, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 17, 2026
Drivetrain Clutch cable?
  • flashback87
  • Jul 14, 2024
  • 2 3
4K
Fox 5.0 Mustang Tech Sep 29, 2024
Need a clutch, 1982 Capri RS 5.0 owner, am I allowed to participate?
  • scudzuki
  • Apr 4, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 7, 2025
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
