problem with speedcal instal
Newbie143
226
what is that gray plastic piece that is supplied with the speedCal and what is it used for?
And what the hell is the E-Z ties?? or is that it (the gray piece)!!!!?
can someone please help me out!? my instal has to stop untill i get these information.
thank you
sorry. here is a pic of the Gray piece i asked about.
sorry its not so clear. Can anyone tell me what I will need this for since the Instal directions didnt mention anything about it.
This is the LATEST update guys.
First, regarding the Gray Scotch connector. I didnt use it , because to be honest i didnt really know how to fit it in there by the cig lighter. BUT i just connected it to the red Hot wire and the SpeedCal was powered fine. I mean DO I "HAVE" to use that scotch connector???
Second, after installing it all , I took the car for a run , and i think the Speedometer is still off, like it used to before!!!! I mean if i did the installation wrong the Speedometer wont work at all , right??
the only thing i might have done wrong is the Number i need to adjust on the speedcal which are 1001001000 for the 3.73 swap. and i did that....so why is my speedo still giving wrong digits!!!!???
thanks
Newbie143 said:
come on guys , someone must know about this. I seriously need HELP :(
Relax dude,Take a deep breath. Scroll down in this link Click Here .
Look at the 5th picture where the guy is holding wires and a "red connector" in his hands. That's the same as you grey connector, only the one they are using is red. You have to remove some of the factory electrical tape from the cigarette/power point outlet wiring and tap into it. The hot lead ( or positive wire) is the Blue wire with thw white stripe. I've got to get back to work, but I'm sure you'll be able to figure it out. Just take your time and you'll be fine. :nice:
