- Jul 24, 2004
- 6
- 0
- 0
Okay I recently bought a 1988 GT 5.0 and when I bought it the tranny was whinning in all gears but 4th. Well I filled it up with Mercon Dexron III to see if that would stop it. Well I drove it down the road to see if it quit but when I turned around to come home I got through 1st, 2nd, and when I put it in 3rd and stomped on the gas it sounded like something broke and started grinding real bad. Well, when you try to put it in gear it will go in fine and clutch still feels the same but when you go to release on the clutch it grinds in all the gears but 4th. It will act like it wants to pull and go in all the gears but it grinds real bad in all but that one. It will start off and not grind at all and drive fine but that is the only gear. Could it be that the synchros in all the gears are gone but 4th or what could it be? I am totally lost.
