  • 1994 - 1995 Specific Tech
Problem with the car running lean
  • Thread starter Thread starter Russ8825
  • Start date Start date Nov 14, 2008
R
Russ8825
  • Nov 14, 2008
I bought a used 95 gt vert (AODE) a couple of months ago. It was a running a bit sluggish (felt like it had no balls compared to my 85) so I gave it a needed tune up, but the car started running worse. The car now has a rough idle and when its cold it chokes for gas. I ran the computer tests and it said the o2 sensor was shot (it said left and right at first, but only right after i cleared the codes.) I changed it but the car is still running rough.
I don't know where to go from here, I was thinking it might be the injectors but I'm pretty lost.
Black95GTS
1,644
Marlborough, MA
Nov 14, 2008
  • Nov 14, 2008
Clean the MAF, check out the IAC. This is probably a sensor issue. A dirty MAF will cause the computer to think there is less air going through then is actual, so it will use less fuel. Less fuel and more air will create a lean condition.
Adam
desertcox05
379
south atlanta
Nov 14, 2008
  • Nov 14, 2008
agreed. if it has a k&n style filter the oil can deposit into the maf and cause all kinds of issues.
R
RumbleFox
15
  • Nov 15, 2008
Russ8825 said:
....it said the o2 sensor was shot (it said left and right at first, but only right after i cleared the codes.)...
LOL dude the EEC pulls codes for a reason. Don't just clear'em and expect it to fix itself. The O2 sensor(s) might very-well be 'effed up. Try replacing both.. hell if that doesn't work, just clean'em off and take them right back and return'em.
HISSIN50
34
129
Nov 15, 2008
  • Nov 15, 2008
If you have a low idle and have been throwing lean codes on both sides, you might have a vac leak.
I would really search for leaks. Then, as noted, pull codes again (be sure to clear codes after you do a repair or modification).
In the interim, you could try to band-aid the idle by playing with the mechanical throttle stop and the idle bleed screw.
Good luck.
R
Russ8825
  • Nov 15, 2008
Cleaning the MAF worked, and I noticed right away lol. The car feels good and like it got its balls back haha
hotcobra03
poteet,tx
Nov 15, 2008
  • Nov 15, 2008
Hisson50 told me to read my book..pcm tell all .record all codes first.dont clear yet. With out loosen pwr to pcm .cover your basics first fuses and battery volts ect....than follow proper diagnostic procedures in pintests....all codes combined together cross a path in the mix.note when the pcm is reset,you c lite go out.what u dont c is pcm goes into a drivecycle .(long story) 1 cycle is long lets say 1hr. It takes some codes up to 3drivecycles to setoff cel.a code that was repaired and not reset will be cleared by pcm after 40 hot restarts.
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
