problem with the stang
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Oct 19, 2005
90mustangfan
93
So cal
Oct 19, 2005
  • Oct 19, 2005
Heres the situation.. Ive been getting codes 41 and 91 for KOEO and KOER....
KOEOR: 41-No hego switching detected running lean (right side)
91-hego sensor cuircuit indicated system lean (left side)
Contienus memory: 41-Hego sensor indicateds system running lean (right side)
91 no Hego switching dected always Lean(left side)
I just replaced my O2 sensors, i checked the wiring all the way to the computer, thats good.It says the car is running lean, I replaced ALL vaccum hoses and hooked them up correctly, it has good vaccum 15hg at idle...What puzzles me is that the car runs great....Any ideas on whats causing it to run lean or why I keep getting these codes...I need to get the check engine light to stop coming on and I need to take it to a smog shop so I can register it...
Numbles
998
Chicago, IL
Oct 19, 2005
  • Oct 19, 2005
Go over all your plastic vacuum lines again. Like the ones on the passenger side. (At least on my 93) And check if any of them are cracked. Like the one that goes to the FP regulator. Or the EGR valve.
Also, check for an exhaust leak at the h-pipe to header connection. Make sure there isn't a leak. If so it could let outside air into the exhaust giving a false reading.
Just my .02
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine 87 NA - Tune or no Tune needed?
  • R82148V
  • Sep 17, 2025
Fox 5.0 Mustang Tech Sep 17, 2025
R82148V
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
