Problem with window off track . help!!!
juecke98gt
Banned
May 31, 2008
78
My drivers side window is off it track but I took the whole door apart and I cant reach the right side of the door. There is only a hole on the left side the rest is metal. Anyone experience this and what can I do. Thanx:D O its 1998 gt
I actually just put mine back on track about a week ago. However, I was fortunate that it was only left side that slipped out. But, from my experience, that is usually the case. Just roll the window down about half way, until the bottom of the glass is showing through the opening and you should be able to see where it should be resting in the track. Then just pick up on it from the top and push it back into the cradle. You could try and do it the proper way and replace the sealant that is supposed to hold it in place, but I never bother, too much of a pain. If for some reason the front side of the glass did come out of place, I would imagine you can try to put it back just by feel. Moving the glass back and forth should tell you whether it came out on the inside or outside of the track (usually to the inside from shutting the door) the do the same as the other end, only without the advantage of being able to see it, just pick up on it and try to "feel" when you get it back... Usually an easy fix.
