Problems at the pumps
05blackstang84
Ok so I'm a new member and this is my first post so if this is the wrong place I'm sorry.
I own a stock 05 GT and depending on what gas station I go too I have trouble at the pumps. It seems the new the pumps the more often I have problems. The problem I'm experiencing is the pump will shut off long before the tank is full. Is this a common occurrence or am I the only one? If not how do I fix this?
It is a common problem, and there are numerous posts about it here. The split tank and venting our cars have cause the pump to quit early, not on all, just on some. However, you can slow down the flow and likely get the tank full without incident.
Turning the nozzle helps, as does slowing the pump down. If you're really worried about it, there is a fix for it, but if you're out of warranty, I believe you'll have to pay to get it fixed at the dealer.
FUEL FILL SLOW, OR DIFFICULT TO FILL TSB 05-4-8
FORD:
2005 Mustang
ISSUE OPERATION DESCRIPTION TIME
Some 2005 Mustang vehicles may exhibit the fuel 050408A 2005 Mustang 4.0L SOHC: 1.7 Hrs.
tank being slow or difficult to fill. The condition may Replace Fuel Tank
be described as, repeated rapid shutoffs of the (Includes Time To Drain,
filling station pump nozzle, or multiple nozzle Refill And Transfer Any
shutoffs when attempting to fill the fuel tank. The Necessary Parts) (Do Not
condition may be due to the fuel tank vapor venting Use With 9002A, 9275A,
system inside the fuel tank. 9350E)
050408B 2005 Mustang 4.6L 3V: 1.9 Hrs.
ACTION Replace Fuel Tank
Install a new fuel tank. The new fuel tank has a (Includes Time To Drain,
revised internal venting system to improve fuel Refill And Transfer Any
filling. Remove the fuel tank assembly per Section Necessary Parts) (Do Not
310-01 of the Workshop Manual. Use With 9002A, 9275A,
9350E)
PART NUMBER PART NAME DEALER CODING
CONDITION 5R3Z-9002-AA Fuel Tank
BASIC PART NO. CODE
9002 42 WARRANTY STATUS: Eligible Under Provisions Of
New Vehicle Limited
Warranty Coverage And
Emissions Warranty
Coverage
Looks like you'll need a new gas tank. Not sure what that'll run out of warranty.
