Mr GT 02 said:
how do u clean the MAF sensor??? and with what???
I think i need to do the same thing.....
Here's the text from an article on the subject...
Cleaning The MAF Sensor
Do you own a 1994-2000 Mustang GT? Have you experienced pinging or detonation at WOT? Well then, this might just
be the fix for you! It seems that many of us that have installed a K&N filter just might have caused the MAF (Mass Air
Flow) Sensor to become dirty. K&N filters are pre-oiled and some of this oil will find its way onto the sensor causing the
sensor to malfunction and in turn cause your engine to run lean at WOT.
Submitted By: TxFrog1999
Now just a quick clarification, this is not the only cause for pinging, and if you own a 2001, it might be your high
compression ratio that is causing the detonation. Ford seems to think that 87 Octane is fine for our cars, in fact on pg.
188 of the 2001 owners manual (some manuals will differ) Ford states:
"Your vehicle is designed to use "Regular" unleaded gasoline with pump (R+M)/2 octane rating of 87. We do not
recommend the use of gasoline labeled as "Regular" that are sold with octane ratings of 86 or lower in high altitude
areas. Do not be concerned if your engine sometimes knocks lightly. However, if it knocks heavily under most driving
conditions while you are using fuel with the recommended octane, see your dealer or a qualified service technician to
prevent any engine damage."
Owners Guide, Mustang (2001 Model Year); Copyright 2000 Ford Motor Company
Now does anyone else find it odd that Ford says its ok for our engines to "knock lightly"? Well I did, and I took my 2000
GT to my dealer for a fix, and according to them Ford has informed all dealers that if any Mustang owner complains
about knocking that they should instruct them to run 93 Octane gas or detune the engine. Now since I wasn't informed of
the possibility that this car would require a high-grade gasoline to run normally and since I won't accept a retune and loss
of performance others and myself decided to find a solution on our own.
WARNING
I am not responsible for mistakes made due to ignorance, lack of patience, or simply following my directions as though
God wrote them.
So before we begin I'm sure many of you have one question on your minds: "Does this work?" Well yes and no. Clear?
Ok, as far as I can tell cleaning the MAF is just as important as changing your oil, and in some cases can stop the light
knocking at WOT. I cleaned my MAF Sensor and it fixed my pinging, but more severe cases of detonation may require a
trip to the dealer as stated in the owner’s manual.
Tools and items needed to complete the cleaning:
T-20 Torx Bit (Tamper Proof)
Electrical Contact Cleaner Quick-Dry Only (Can be found at AutoZone for around $2)
Note: The MAF Sensor is VERY delicate, so be sure to remove it carefully and never touch the sensor directly!
This is the MAF Sensor:
First, disconnect the sensor from the electrical harness:
Next, use the T-20 Torx bit to remove the two bolts connecting the MAF sensor to the air box:
Now remove the MAF Sensor, and remember to be careful because the sensor is delicate!
Here is the sensor, use the contact cleaner and spray a generous amount on the sensor. Allow the vapors and cleaner to
evaporate fully.
Now reinstall the sensor, make sure to reattach the harness and take her for a test drive.
http://www.stangnet.com - Ford Mustang | StangNet.com Powered by Mambo Generated: 10 April, 2005, 19:21
