Problems with 60fts, need some guidance
  • Thread starter Thread starter thinker
  • Start date Start date Sep 26, 2005
T
thinker
182
Corona, Ca
Sep 26, 2005
  • Sep 26, 2005
I went to the track last sat and my 60fts were all in the 2.30-2.60 range, really bad but my mph trap speed was between 96-98mph. Motor is stock with 100k on it with just full exchaust, cai and 14* timing. Suspension is front swaybar delete, lakewood 90/10s front, 50/50s rear, maximum motorsports lca's, stock uppers, eibach drag launch spring kit with the the airbag and bfg dr's out back with skinnies in the front. Question I have is what am I doing wrong? I did a 5sec burn out before I saw the tires smoke and I was launching at 4500rpm all night. I still have my factory quad shocks on, should I take those off? And the airbag right now has 14lbs, never really adjusted it, I read some ppl putting in 20psi in the airbag, whats a good starting point for stock motor? oh and I was running 14lbs in my rear tires. Thanks for the help
kck6894
Advanced Member
Mar 18, 2004
Paradise
Sep 26, 2005
  • Sep 26, 2005
try adjusting tire and air bag pressure up and down till you find what hooks best. You need to get adjustable uppers so you can adjust your pinion angle. Pinion angle will make a big differance
Bigstang1
415
Massachusettes
Sep 26, 2005
  • Sep 26, 2005
wow you should def be getting more out of that suspension setup...i run 2.3 sec 60 fts with stock upper and lowers , street tires (radial ta's), kyb shocks, stock motor w 186k 94 mph trap speed . you should be much better...i would say play with the pressures somthing is very off there. goodluck
ninety15.0
1,336
  • Sep 26, 2005
u must be spinning....what gears are in the car?
L
luckythirteen13
648
Anaheim, CA
Sep 26, 2005
  • Sep 26, 2005
if the engine is mostly stock maybe your bogging it
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Sep 26, 2005
  • Sep 26, 2005
That's what I was thinking, that and a stock gear.
T
thinker
182
Corona, Ca
Sep 27, 2005
  • Sep 27, 2005
I have 3.73s in the rear and launching at 4500, I dont remember it bogging just spinning off the line. I had 7lbs in the airbag on those runs. When I did my best 14.20 2.17 60ft at 98mph I had I think 14lbs in the bag, I totally forgot at the track at the time to adjust air pressure.
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
J
Need Help: 95 Mustang GT Engine Rebuild
  • jurban421
  • Jul 25, 2021
  • Other Auto Tech
2K
Other Auto Tech Jul 25, 2021
jurban421
J
Progress Thread diving back into my 87 lx after a 10 year hiatus need some advice
  • 87fox72mach
  • Apr 30, 2020
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 2, 2020
87fox72mach
For Sale 1994 cobra coupe, 150k mi, 5spd, 5.0L, $5k obo, Ewing, NJ
  • 94cobra4sale
  • Oct 9, 2019
2K
SN95 Mustangs For Sale (1994-04) Oct 9, 2019
94cobra4sale
9
  • Locked
SOLD 1990 Mustang Gt Supercharged, Refreshed/restored With 486rwhp
  • 1990Mustang
  • Aug 20, 2017
3K
Fox Body Mustangs For Sale (1979-93) Aug 20, 2017
1990Mustang
