I know problems like this can be frustrating. Just keep plugging away at it. You’ll get it.
Fix your known problems, the alternator wires. Then see if the problem still occurs.
Again, your analysis is correct. Your alarm will kick in if the voltage drops too low. It definitely appears to be a grounding problem. Just like everyone above having the same issues; something in your car is grounding out. Fix the alternator connector and then inspect around areas where wire insulation could have been damaged, i.e. by the battery and areas with a great deal of heat.
I suggest the following. Carry a voltmeter in your car. The next time your car doesn’t start, have someone or you apply the voltmeter across your battery to measure the DC voltage. Start the car. From memory, it shouldn’t drop below 10 volts or so. To determine what the normal voltage is, perform this test when the car starts right off. If the voltage drops excessively, it does have enough amps (power) to turn over your car. This condition could be caused by a bad battery, bad alternator, a short, or something like this.
From the information you’ve shared so far, it appears that the alternator is not fully charging the battery or shorting it. Since you were trying to start the car, the battery is doing all the work. It has to have enough amps to turn your starter. But, it couldn’t. It could be because your battery didn’t have enough amps in it to turn over your motor or the battery was being shorted out, somewhere, not allowing it to provide enough current to the starter.
I’m sure I don’t have to say this, but this is a serious condition since a battery could explode if it’s being shorted out.
One last question, how long have you had your underdrive pulleys installed?
Good luck,
p51302
