The II broke down in an Albertson parking lot. The starter just whines but I dont think that is catching the flywheel. The starter and the car were running perfectly before all this. any ideas?
II many problems and so little $$$
.. hope its something insignifigant.. we all know about flywheels for ii'scobraii74x said:Did the starter grind or sound like it was working harder than it should be to turn over the engine ? .. The same thing happened to my brother's truck and the starter wasn't fully engaging the flywheel and it ended up chewing the teeth off of the flywheel.. hope its something insignifigant.. we all know about flywheels for ii's
cobraii351 said:Sounds like the drive in the starter nose died. You might get away with just replacing the drive gear/clutch.
Tim
IICrazy said:I have a lifetime warranty on the starter, so I will just replace it. I'll know more when I get the car home and tear into it.
zwhitr said:go with the drive replacement if it sounded good before. Once you lose the original fitting casing its all down hill As a matter of a fact some folks just have their original rebuilt. I know you said it was a lifetime but there are differences in the casings Trust me!!!!
Wart said:And part's houses are filled with trained Monkeys who couldn't find the difference if you gave them a map.
Trust me.
Stewart Ledford said:OK GUYS THERE HAVE BEEN CONSIDERABLE PROBLEMS WITH OUR STARTERS C4 MUSTANG II 302. I WENT THROUGH A LOT OF WORK AND RESEARCH TO LEARN THE II USES A DIFFERENT STARTER DRIVE. NOT ALL THE REBUILDERS KNOW THIS, NOT ALL THE REBUILT STARTERS COME WITH THE CORRECT DRIVE. THE DRIVE ITSELF IS II SPECIFIC AND ONLY FITS MUSTANG II V8, & MAVERICK AND OTHERS WITH 200 & 250 C.I. SIX CYLINDER ENGINES. IT IS AVAILABLE AT AUTOZONE
laughs....hey thats great.....you can also push start....us C4 guys are really stuck.....can carry a spare starter in the tire well but then removing that motor mount and header & lifting the engine along a busy highways a real bitch.IICrazy said:Thats fine but I have a 4spd and can pick up a starter anywhere
Stewart Ledford said:laughs....hey thats great.....you can also push start....us C4 guys are really stuck.....can carry a spare starter in the tire well but then removing that motor mount and header & lifting the engine along a busy highways a real bitch.
Glad you figured out your problem.
Stewart
IICrazyIICrazy said:Got the starter out, and there were no bolts holding it in. The bolts must have worked themselves loose, There is an oil leak that drips directly ontop of it. The flywheel is dinged up, but not too bad, the starter bolt hole is gone.
Does anyone know the sizes of the bolts for the starter?
