  • 1994 - 1995 Specific Tech
Problems with the GT.
  • Thread starter Thread starter RiceEatin1995GT
  • Start date Start date Sep 25, 2004
1 of 2 Next Last
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
I just recently got my 1995 GT on monday. I don't really know a whole lot about cars, but I'm slowly learning and know my Stangs pretty well. Yesterday, I was backing out of my frinend's driveway when it sounded like it stalled, but right before I went to turn the key again, it revved back up again and was fine, as if it wasn't getting enough gas. Well, the other day I heard a low whining under the car so I asked my dad about it (30 year mechanic), and he said it sounds like the fuel pump is going bad. Would that cause the car to spontaneously temporarily stall like that? We're gonna get it fixed soon probably once this hurricane passes. We'll jack it up and do it ourselves. And whenever I go over bumps, the driver's side rear end squeaks.. I heard it's probably the bushings. What do you guys think? It's pretty annoying hearing it squeak everytime I go over a speed bump. >_<
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
Buuuuuuuuuuuuuuuuuuuuuuuuuump.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Sep 25, 2004
  • Sep 25, 2004
Sounds like the upper or lower control arm bushings need to be replaced.
N
NightStalkersSO
62
Gilbert, Az
Sep 25, 2004
  • Sep 25, 2004
My car does that sometimes too, only when I first start it up, it drops RPMs real bad then goes up to like 1200 surges maybe a couple more times and then finally levels out....I think it's the tps, or maybe the engine just needs cleaned real good, I've got 141k miles, so who knows.....anyone wanna back that up, or am I totally off???
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
How much do those cost? Could I just use silicon lubricant spray to minimize it for now?
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 25, 2004
  • Sep 25, 2004
Hmmm, it didn't do that. It just sounded like it died, and then came back to normal. Mine has 90,600 miles.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 25, 2004
  • Sep 25, 2004
Does it stop once the cars warmed up? It may be your mass air meter. Mine used to idle like it had a cam until it warmed up then it was fine it turned out to be my mass air.
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Sep 25, 2004
  • Sep 25, 2004
i had the same problem NightStalkersSO, it could be that or possibly you're mass air flow sensor could have oil on it from the last time you recharged your k&N filter. Happened to me once or twice, almost embarrassing, then the car saves itself.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 25, 2004
  • Sep 25, 2004
I'm not to sure on what they cost. The spray may work for a little.
xr8d302
Apr 29, 2004
1,113
Medicine Hat, AB
Sep 25, 2004
#10
  • Sep 25, 2004
  • #10
oh crap, didn't notice we had posted the same thing...i was messed up
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Sep 25, 2004
#11
  • Sep 25, 2004
  • #11
N
NightStalkersSO
62
Gilbert, Az
Sep 25, 2004
#12
  • Sep 25, 2004
  • #12
Yeah, doesn't generally do it once it's warmed up, but I drove to the gas station like 4 miles away, filled it up, started it and it died....That's not really warmed up though. And it doesn't always do it either, just sometimes. I'll check the maf though
HoofnIt
1,175
North Carolina
Sep 25, 2004
#13
  • Sep 25, 2004
  • #13
It doesn't really sound like a MAF problem. Have you cleaned your throttle body yet? Maybe the IAC valve has some crud in it?
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Sep 25, 2004
#14
  • Sep 25, 2004
  • #14
Don't use carb cleaner in your IAC valve to clean it. I did, and it broke mine. Just saying from experience. Carb cleaner shouldn't hurt it, but for some reason it hurt mine.
Try some WD-40 instead.
Secondly, did you have the steering wheel turned all the way over (either direction) when you were backing out of the driveway? If you do, it will make the motor want to stall, and once you turn it back, the motor revs back up. This is completely normal when you consider the PS pump is probably a factory piece and has seen MANY miles!!! Mine does this, so I thought I would share.
Also, this dull whine you are hearing is probably your fuel pump. Many times the pumps will do this, even when they are brand new. Mine whines, as well as many others on this board. Completely normal.
Put the key in the ignition, and turn the key to acc., but don't start it, you should hear the dull whine for a couple seconds, and then it will go away. What you are hearing is the fuel pump priming for the initial start.
Your suspension is probably factory as well. I can't tell you what it creaking & moaning, but it could be your springs, shocks, ball joints or bushings. Remove the front wheels, and inspect the components. Look for obvious wear.
Someone let me know. Can you fill our bushings & ball joints with a grease gun? I am not sure, so I wanted to ask. If you can, I would try that. If you can't, then try some WD-40. It should quiet it down temporarily until you replace what is squeaking.
Scott
WhiteStallionGT
465
Northern VA / VT
Sep 25, 2004
#15
  • Sep 25, 2004
  • #15
wow, i have the same prob with my car, today, i was backing out of my driveway, when i put it into drive it sort of stalled then the engine turned off. My guess is the fuel pump, i'm taking it to the mechanic.
98_stang_guy
121
Wisconsin
Sep 25, 2004
#16
  • Sep 25, 2004
  • #16
my car, once it gets to about 1/4 tank, it it will cut out every now and then because of the fuel pump, i just fill it up when it gets to 1/4 instead of fixing it tho
R
RiceEatin1995GT
21
West Palm Beach, FL
Sep 27, 2004
#17
  • Sep 27, 2004
  • #17
Scott
I don't think so but I may have had the steering wheel all the way turned. I can't remember. I'll have to try that with the fuel pump. I'll also mention it to my dad. Thr front wheels? The squeaking I'm pretty sure is coming from the back drivers side wheel.
CManT1914
3,172
Killeen, Texas
Sep 27, 2004
#18
  • Sep 27, 2004
  • #18
The squeak is most probably your control arm bushings. Mine did the same thing. While you CAN oil them, it's not worth it. It wears off real quick and it's back to squeaking. Another thing that made my rear-end squeak was my rear sway-bar. It was loose and squeaked for a long time.... until it snapped in half! lol. Check those out, make sure they're good and tight, and you might need to replace some bushings. No big deal though, personally, I think the rear suspension is the easiest part of the car to work on.
gcomfx.com
3,690
Republic, MO
Sep 27, 2004
#19
  • Sep 27, 2004
  • #19
My squeak in the rear of the car was the emergency brake cable going through the built in loop under the car. I would drive me crazy. Little white lithium grease and all is well for months.
The loop is in the area between the back wheels and the door. Just follow the cables, you can't miss it. Squirt it down and then push up and down on the trunk... could save you some money if that's the problem and not control arms. ;-)
donjohn
1,757
Irvine - Southern California
Sep 27, 2004
#20
  • Sep 27, 2004
  • #20
LISTEN TO MO DINGO ABOUT EVERYTHING. i was just about to post the same thing. The wine is the fuel pump but it's fine, the near stalling is the power steering which is also fine, usually when i'm turning the wheel it does the same thing u just have to remember that when it sounds about to stall, stop turning the wheel. my ps also makes a medium pitched grinding type noise u get with most ford ps pumps. as for the question modingo asked about the grease gun- no idea, when i sprayed my bushings and such it wore out pretty quick. i also live with the squeak over every bump and a loud low pitched creak at low speeds when turning.. unless u want to put out $$, deal
1 of 2 Next Last
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Dipstick Issue?
  • Sonic
  • May 2, 2026
1994 - 1995 Specific Tech May 5, 2026
WhiteCobra95
L
Help with 1986 GT 5 Speed Please
  • Lcasada1999
  • Mar 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
