Prochamber scrapes on speedbumps
I had a 98 gt and had eibach progressive rate springs, it droppedthe car 2 inches all around , and my car dragged over every speed bump, my h pipe was all dented up, and that from driving over them very carefully, my new gt is still stock height and i dont have any problems with speed bumps with aftermarket mid pipe and catback.If your car is lowered you will just have to avoid speed bumps or drive over the very slowly..Jayson
supastang03 said:
is this normal? it only happens every once in a while, but it gets me really nervous. is it getting loose? or is this just normal...?
Its normal. The chamber sits low, but check for leaks and to make sure the nuts on the manifold bolts are still tight. Mine came loose on the driver's side and I developed a leak.
