Procharger and Vortech
srad 750
I have a V1-STrim setup for a fox and want to know if anyone has tried putting a procharger front mount intercooler with this set up. Also is there any way to make the vortech blow of valve work as open atmosphere like procharger?
you could do it, but its going to be alot of work, 1991vert has a novi 2k with a front mount, and he ended up mounting his intake backwards and running the pipe throught the washer resivior hole. If it was me i'd just get a procharger, the main problem is that you want to keep the bends to a minimum and the intake tube from the IC shoud be kept away from heat sources as much as possible, which is difficult when the intake and blower are on the same side of the engine
