It's leaking from where the intake clamps onto the charger.. It also appears to be leaking from the front underneath the charger--I think the second leak is from the drain plug, but if there is a common place near that let me know...
I've done alot of searching and I keep hearing I need to send it off to procharger and wait 6 weeks...That's out of the question...My guess is that it's just a seal I need to replace..
....I'm sure a seal can't be THAT hard to replace...I know everything is balanced, so as long as I mark the position of the blade, etc with whiteout and respline everything the way it came apart I should be ok right? Where do I get seals? Can I just buy a reseal kit, or should I buy some sort of reman kit with bearings, etc??
Second leak is coming from my Moroso Intake breather...I'm not really to sure how to solve this leak???? It leaks out and burns off the exhaust, really looks bad when I turn my car off and have smoke coming from the rear of the cowl hood. Maybe buy a longer breather with an extension to prevent oil from splashing out??? I have already replaced the breather with the chrome head type that is suppossed to prevent this.
....I'm sure a seal can't be THAT hard to replace...I know everything is balanced, so as long as I mark the position of the blade, etc with whiteout and respline everything the way it came apart I should be ok right? Where do I get seals? Can I just buy a reseal kit, or should I buy some sort of reman kit with bearings, etc??Second leak is coming from my Moroso Intake breather...I'm not really to sure how to solve this leak???? It leaks out and burns off the exhaust, really looks bad when I turn my car off and have smoke coming from the rear of the cowl hood. Maybe buy a longer breather with an extension to prevent oil from splashing out??? I have already replaced the breather with the chrome head type that is suppossed to prevent this.
