Professional Products Harmonic Balancer
  • Thread starter Thread starter mustangman1974
  • Start date Start date Jul 26, 2005
M
mustangman1974
463
  • Jul 26, 2005
I have noticed this company actually makes a 50oz with the old 65-66 harmonic depth for v-belt alignment. Has anyone used these harmonic balances before? I am finalizing my motor for my mustang and would really not have to fab brackets for the accessories. I was plannign on using the windsor-fox, or ford balancer, but this one look slike it will save me hours on fabing. My motor shoudl make around 385hps when complete so it not to mild.
What does anyone think about these balancers?
G
grego37
576
Fresno CA
Jul 26, 2005
  • Jul 26, 2005
ive never heard of them.
but then again, it was 10yrs ago when I was piecing together my parts.
M
meganjoe
35
The Poconos
Jul 26, 2005
  • Jul 26, 2005
yes i have one on my 5.0...i originally had a 289 then swapped in the 5.0... the interchangable weights came in handy when i went from 28 to 50 oz...i also believe it was under 100 bucks...Joe
TampaStang
67
Tampa, FL
Jul 26, 2005
  • Jul 26, 2005
Got one on my 5.0 so I could use the old belts..
347Fastback
340
Central Coast
Jul 26, 2005
  • Jul 26, 2005
Got one on my 331 and it works fine... They are good deals on ebay for this particular balancer....
M
mustangman1974
463
  • Jul 26, 2005
Those of you with it how often do you drive your rides?
Mine will be a daily driver. I currently have the stock balancer with modified brackets and an underdrive crank pulley for a 70 302 on it.
Also has anyone used the Ford balance drilled for both 3 and 4 bolt pulleys? I have looked and it states its 3.5 in wide. The stock for perfect alignment is 2.78-3 I believe.
06cobra
146
  • Jul 27, 2005
Anything by Professional Products. SUX big time.. quality, fit etc is very low. Very disappointed by the entire line.
The intakes are the WORST garbage I've ever seen.
and yes I'm holding back LOL
12sec67
1,301
San Diego, Ca
Jul 27, 2005
  • Jul 27, 2005
this is what i have in chrome.
ebay link:http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&category=33616&item=7987612545
i did have to have the inner diameter ground down for the crank but it said i needed to in the directions.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Jul 27, 2005
  • Jul 27, 2005
That may be, but do you actually have experience with the whole product lin....or just an intake? Maybe give some specifics before condemning the whole company.
I have a PP damper that I needed for the same reason as eveyone else(5.0-->classic), but I have yet to use it. It looks decent, but I knew the possibility of it being junk before I bought it(~$78 eBay). It just nodular iron, so its like a stock replacement, but about $30 less than a parts store.I also compared it to my old 1968 part and the dimensions were the same.
06cobra
146
#10
  • Jul 27, 2005
  • #10
We have experience with the whole product line.
Offshore Junk, plain and simple. They are catching up with their foundry and casting procedures etc. But as of this date.the metal composition is terrible, product finish is horrible. For bone stock replacement MAY be ok, but I wouldn't trust it. If dampener lets go, it can make one heck of a mess.
As for the intakes, the darn things look like they've been put together with a puddy knife. Definitely 2 Thumbs down for the entire line. Cheap low quality rip offs is the name of the game. They are great at that game.
EDIT: Power Bond, ATI and others do make Dampeners that work in the Vbelt config. In either 28oz or 50oz
D
DKWilkins
12
Dublin, GA
Jul 27, 2005
#11
  • Jul 27, 2005
  • #11
I used a harmonic balancer by Fluidamper on my Mach 1. I'm very pleased with it.....
fwiw....
ARPM
116
PUERTO RICO
Aug 3, 2005
#12
  • Aug 3, 2005
  • #12
Since this is a topic of Dampers, Does anyone knows were can i get a chromed 28oz 3 bolt damper for my 68 302? Used or New?
:OT:
skywalker
733
Pensacola, FL
Aug 3, 2005
#13
  • Aug 3, 2005
  • #13
You're the only person I've seen with negative, specifically about the intakes. Most people simply complain that it's not "buying american" (true enough) but wow you really take them to task. Personally, my experiencewith the intakes specifically, though *I* do not personally own one) is that they were good Edelbrock rip offs.
J
jbuening
399
Aug 4, 2005
#14
  • Aug 4, 2005
  • #14
I personally own the Pro Products SFI damper and the polished aluminum Typhoon Intake. The only fitment problem was the clearance around the distributor to the clip on the dizzy that snaps the cap on. I had to grind the top edge a little to be able to move the dizzy to advance my timing. Fittment is exactly like the Edelbrock that i had on it before except for that minor trimming that needed to be done. The damper was dead on according to my machine shop when the rotating assembly was balance. Maybe you got a bad one?
allcarfan
The Answer Man
2,458
North Atlanta
Aug 4, 2005
#15
  • Aug 4, 2005
  • #15
i bought a PP balancer for my 475hp NA 331. Havent had a chance to use it yet, but my engine builder says that it looks a helluva lot better than ones he has seen come from the parts store.
I also have a polished hurricane PP intake. I test fitted it on my old engine and there was nothing wrong. There is a little bit of smoothing that could be done to the inside of the intake, the runners could be opened up a bit, and the polishing just needs to be touched up. Nothing major at all. For $175 shipped...new, and polished, I couldnt beat it. It was hard to find the equivalent Vic Jr carb intake used and not polished for that price.
10secgoal
2,801
San Diego
Aug 4, 2005
#16
  • Aug 4, 2005
  • #16
I have a CAT balancer. It has held up for a few years with constant abuse.
LMan
1,246
Mom's basement
Aug 4, 2005
#17
  • Aug 4, 2005
  • #17
I have a balancer with the interchangable weights, and it also is drilled for both 3 an4-bolt pulleys. I'll take a look when I get home and see what brand it is.
M
mustangman1974
463
#18
  • Aug 4, 2005
  • #18
Well I actually did more research on the harmonic balancer. It looked good. I finally recieved an email from my connection at Ford and found out that ProStreet makes ford SVO's balancers. I purchased one drilled for 4-3 bolt pulleys. So far it looks ok, however it is 1/8 in bigger so I have to grind my bosses on the front cover to get it to work.
10secgoal
2,801
San Diego
Aug 4, 2005
#19
  • Aug 4, 2005
  • #19
A little grindin gitsn't unheard of. I had to grind my water pump.
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
W
1966 mustang 289 Balance mystery
  • Wardy
  • Aug 15, 2019
7K
Classic Mustang Specific Tech Aug 20, 2019
Wardy
W
Engine Romac Balancer question
  • Justin87
  • Oct 6, 2019
3K
Fox 5.0 Mustang Tech Oct 8, 2019
08GT500
Foxtoberfest 2022
  • FastDriver
  • Sep 6, 2022
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2022
Ford Moore
F
