Hello all,
Put in some garage time this weekend on my “inherited” 306 motor and could use some of this forums sage advice.
Assembled the bottom and front end of the motor and ran into a bit of a snag with my harmonic balancer.
The motor came with a Romac steel 50oz balancer. The paperwork from DSS Racing said that it should use a 50oz balancer and a 50oz counterweight on the flywheel.
Using an installer tool, I put it on, but it was a tight. Holy smokes it was tight. The balancer instructions called it a “partial interference” part and it warned me that it would be tight and to use a lot of oil, or even heat it up in the oven.
My questions are:
1. Are Romac parts no longer made? Finding information about them online has been difficult. This one was still new in box because it came with my motor, but the motor was originally ordered from DSS in like 2009. It seems like they aren't readily available.
2. Is their an established method to knowing that it’s on all the way? The stock balancer has a hard machined lip on the shaft of the balancer but this one is curved. (See attached pictures)
Basically, I’m ask if their is a danger in letting the crank bolt finish the job since I’ve gotten it so close.
3. How much is this going to suck if for reason I need to take it off. Anyone have experience with one of these? I did oil it, but it was a beast getting it on.
I’ve read a few threads on here with people discussing the pros and cons of buying them, but anyone pulled one off recently?
My questions are:
