proform electric fan
  • Thread starter Thread starter NFGTragedy
  • Start date Start date Aug 3, 2006
N
NFGTragedy
155
Rochester, NY
Aug 3, 2006
  • Aug 3, 2006
Just curious how to get it wired in so it doesn't run when the car is off... I have it right now wired direct into the fuse panel using a spade connector but it continues to run with the car off and drains the battery... Is there any way to wire the hot so it only runs when key is on?
HISSIN50
34
129
Aug 3, 2006
  • Aug 3, 2006
Sourcing power from the interior is NOT how I'd do it. But if you must, simpy choose a fused power source that is only key-on hot. It sounds like your existing power source is always hot.
Instead, I'd run a relay under the hood - it's safer, doesnt need a big power donor from the interior and allows the fan to perform better.
Good luck.
Kumm3
527
33
69
East Hartford, CT
Aug 3, 2006
  • Aug 3, 2006
i have mine wired right into the ignition relay, therefore, as long as the key is on, so is the fan.
N
NFGTragedy
155
Rochester, NY
Aug 4, 2006
  • Aug 4, 2006
How did you do this? Mines run to interior and its just plugged basically straight in the fuse box and it runs with the car off which is just crap for my battery.
Kumm3
527
33
69
East Hartford, CT
Aug 5, 2006
  • Aug 5, 2006
the post opposite of the battery side of the solenoid.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Aug 5, 2006
  • Aug 5, 2006
Good luck.
This is the info you're looking for.
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
