  • 2005 - 2009 Specific Tech
Programming the ECU - What are the options?
  • Thread starter Thread starter Big-Foot
  • Start date Start date Sep 20, 2005
1 of 2 Next Last
Big-Foot
123
Kenyon, MN
Sep 20, 2005
  • Sep 20, 2005
I'm not particularly interested in re-programming for more power, but better driveability.
I would like the throttle to release quicker when I let off the pedal. The dashpot setting in the ECU has way too much delay in it - I've read some people say it is as long as 4 seconds. Mine is maybe two-three seconds.
What are the different tools available and has anyone developed a home brew control system for this ECU yet like they have for the EEC-IV and the GM ECU's (which I am very familiar with) ???
Please tell us what tuning tool / service you use, how much it cost and if it will do what I am asking for..
Thanks!
Big-Foot
123
Kenyon, MN
Sep 20, 2005
  • Sep 20, 2005
Stumped you guys eh?
R
royb
273
  • Sep 20, 2005
Thanks!
youwant the xct2 with some good street tunes the throttle lag will go away .
Big-Foot
123
Kenyon, MN
Sep 20, 2005
  • Sep 20, 2005
Hi Royb
I did a websearch for "xct2" and did not find anything relative to a Mustang.
Do you have a link or vendor for this?
Thanks!
G
gp001
4,401
So. Cal.
Sep 20, 2005
  • Sep 20, 2005
I have the Diablosport Predator and it works great.
bleedingvayneAD
339
At my computer, duh
Sep 20, 2005
  • Sep 20, 2005
Big-Foot said:
Hi Royb
Thanks!
Here ya go....
http://www.mustangtuning.com/sct-xcalibrator-2.html
Big-Foot
123
Kenyon, MN
Sep 21, 2005
  • Sep 21, 2005
bleedingvayneAD said:
Here ya go....
Thanks for the link. I looked at the website but it doesn't say anything about adjusting for throttle lag.
This XCalibrator seems to have a few more features than the Diablo when it comes to connectivity to PC's etc.
Any comments on functionality?
Also - Am I presuming correctly that once you adjust the parameters you want, that you disconnect the device from the car?
Thanks guys!
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Sep 21, 2005
  • Sep 21, 2005
You can not tune for throttle lag with any of them, but after tuning my GT, the throttle lag disappeared. These cars are just tuned so crappy from the factory for emissions.
Don't expect it to do everything it says, but it does quite a bit, and I love being able to customize my tune right on my pc. If I get new gears or wheels/tires I don't have to pay for a new tune...
But I will warn you, it will give you more power
Big-Foot
123
Kenyon, MN
Sep 21, 2005
  • Sep 21, 2005
Darkfire - Thank you..
Is there any way to download and store the programming that is currently in the ECU so it can be restored at a later time if needed?
Also - Does the device get disconnected after you do your tuning or do you have to leave it connected?
Thanks again!
W
WSD42
52
Madison, AL
Sep 22, 2005
#10
  • Sep 22, 2005
  • #10
With the Diablo Sport Predator...it stores the OEM tune first and then you follow the directions it gives to load the new tunes. By storing the OEM tune in the DSP, it then locks the DSP to your car. There are several optional tunes:
- 87 Octane tune
- Factory Performance tune
- 91 Octane tune
To name a few off the top of my head.....
When you finish with the tune install...you disconnect the DSP from your OBD II Port (on the left side under the steering wheel). You can leave it connected for data gathering and diagnostics, but after a tune is installed, you disconnect the DSP when it tells you to, and not before. Follow the instructions on the tuners and you should not have a problem.
If you add a CAI (Cold Air Intake) from either Steeda or C&L the DSP has tunes you download from Diablo Sport to handle this. The C&L can be ordered with the DSP and the proper tunes for you car already installed. C&L is local to me, so I have been there and talked with them. They have used my car for a few measurements and such.
The SCT Xcalibrator I & II are much the same as the DSP. I have the DSP with rev23 and the Steeda CAI custom tune loaded on my '05 GT. The SCT II is better than the SCT I, but I picked the DSP and have no problems with it.
Hope this helps!
DarkFireGT
692
10
89
East Moline, IL
Sep 22, 2005
#11
  • Sep 22, 2005
  • #11
Thanks again!
Yes, you can store the tunes right on your computer. I've got 10 stored right now, soon to be 11. I'm going to make one with a rev limit of 3500 for when I take it in for paint.
The device disconnects, unless you want to datalog. But normally, it's disconnected. It just reprograms the computer and it's job is done.
N
nbk13nw
186
Newport News, Va
Sep 23, 2005
#12
  • Sep 23, 2005
  • #12
The throttle lag from the ETC (Electronic Throttle COntrol) cannot be directly affected using the handheld tuners. A full software package will allow you to adjust the parameters to remove the lag. Most full SCT / Diablo tuners have this available. A good trune can take it out. Doug at BamaChips comes to mind.
Big-Foot
123
Kenyon, MN
Sep 23, 2005
#13
  • Sep 23, 2005
  • #13
Thanks for the information guys...
Like I said before - I'm very familiar with GM programming (I've burned a lot of chips) and I've also done some ECU re-design work on the Victory Motorcycles.
This ECU is (so far) foreign to me. I will probably see if I can purchase a used one on eBay and figure out a method of re-programming via Serial / USB port and potentially a dongle..
Has anyone else out there played / hacked with one?
Another question - Are tunes "Serialized" to the car's VIN? In other words - is there any way to share tunes with this ECU?
bleedingvayneAD
339
At my computer, duh
Sep 23, 2005
#14
  • Sep 23, 2005
  • #14
There is no way to share tunes, or tuners for that matter, because once you plug in the tuner into your OBD, it is then serialized to your car.
Big-Foot
123
Kenyon, MN
Sep 23, 2005
#15
  • Sep 23, 2005
  • #15
So - in other words - when someone trys to sell a used Predator or XCalibrator on ebay, it would be a good idea to just pass on the deal...
That's sort of bogus... We gotta fix that!
bleedingvayneAD
339
At my computer, duh
Sep 23, 2005
#16
  • Sep 23, 2005
  • #16
One would hope that when used ones are being sold that they haven't been used yet because that's like selling girl scout cookies with bites already in them. Kind of, I guess?
tom281
253
NE Indiana
Sep 23, 2005
#17
  • Sep 23, 2005
  • #17
My understanding is that as long as the factory tune is reinstalled into the handheld by the original owner, it can be sold and reused by someone else. I'll find out for sure tomorrow, cause I'm selling my Predator at 10:00 a.m.
ts
N
nbk13nw
186
Newport News, Va
Sep 23, 2005
#18
  • Sep 23, 2005
  • #18
That is correct... If you want to sell your tuner. You must first reflash to stack which will unlock the tuner. I know with the SCT after I bought it I still had to "Unlock" it with the application as well.
tom281
253
NE Indiana
Sep 23, 2005
#19
  • Sep 23, 2005
  • #19
While I got you online, how do you like the Excal 1 for your '05? I have a thread going on now, looking for people's attention.
O
official_style
261
#20
  • Sep 24, 2005
  • #20
go with sniper! this was what was used to tune my car. you would want the sniper scout if you want to connect to your laptop.
http://www.snipertuning.com/new/view.phtml?f_cat=Electronic+Tuning
1 of 2 Next Last
Engine Information that is Needed When You Post a "Car is not Running" or "Car is Running Poorly" Thread
  • AeroCoupe
  • Apr 28, 2025
Fox 5.0 Mustang Tech May 4, 2025
Bullitt347
Engine No start issue AGAIN!
  • ucnhtmenow1
  • Sep 1, 2024
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 11, 2024
89ripper
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
