  • SN95 4.6L Mustang Tech
Progressive vs non progressive springs.
  • Thread starter Thread starter JohnyD05
  • Start date Start date May 30, 2005
J
JohnyD05
417
Massachusetts
May 30, 2005
  • May 30, 2005
I am considering the maxium motorsports sport box, i belive it comes with new springs. and i was wondering what is everyone opinion on wether to get progressive or non progressive springs, anyone experience in there cars? advantages, disadvantages?
triggz
1,218
Gadsden, AL
May 31, 2005
  • May 31, 2005
Basically...
Progressive springs rate increases as they are compressed. (Your lowered car wont squat to the ground when weighted down)..
Normal springs (like stock) have the same resistance until full compression.
This is why its safe to cut stock springs without fear of hurting the rate.
hotrodnut
672
North Florida
May 31, 2005
  • May 31, 2005
Progressive springs will work your shocks more than a linear spring will. By that, if your springs are progressive the rate gets higher as it compresses, therefore the shock has to work harder to keep the spring from bouncing more. The advantage of progressive springs are of course a better ride when not being pushed but will be stiffer when put through the loads of force from cornering. Progressive springs will also help to eliminate the bottoming out the spring when it is compressed to the maximum extents of travel.
A top grade shock/strut with a wide range of compression and rebound control for the different rates that are encured from a progressive spring going through its travel will be required if that type spring is used.
The advantage of linear springs is more constant spring rates while cornering and the effects of the shocks acting with it are more equal during the changing of forces applied to the springs.
For me, I have found that a linear spring is more predictable and has somewhat better (more constant) feedback while pushing your car to the limits during cornering.
I could not find a linear spring front and rear combo for my Mach1 that had the spring rates I wanted. I have the linear up front and the progressive with a very small difference in rate change on the rear. I have found that when at full tilt in a corner the rear will give me a slight pogo effect even with my shocks set on the full hard setting when I encounter a dip in the road surface.
J
JohnyD05
417
Massachusetts
May 31, 2005
  • May 31, 2005
what linear and what progressive rate springs do you recomend with a decent drop but not too much?1 if you know what i mean. what do you have on your mach 1, hotrodnut?
hotrodnut
672
North Florida
Jun 1, 2005
  • Jun 1, 2005
I have linear 700 pounders up front and progressive 275-300 in the rear. You can look in my Garage to see the amount of drop it gave my Mach1 (picture with the black Racing Sparco wheels in my Garage photos).
I was actually looking for more around 650# up front and 300# in the rear to help get rid of the heavy understeer the Mach1 has from the factory with a 1.25" drop up front and 1.50" drop in the rear. What I have gave me close to 1.25" on all 4 corners but recently I installed Steeda's adjustable weightjacker lower control arms and I dropped it another .25" in the rear (picture with stock Mach1 wheels in my Garage photos). The dimensions I quoted are from the standard Mach1 spring ride height which is around .50" lower than the standard GT springs to start with.
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
N
Fox Street Suspension Build Advice
  • NYFox
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 28, 2026
For Sale Ford Motorsport 160 Mph Speedometer - $325
  • TTSaleen
  • Nov 5, 2026
  • Interior Exterior Parts
Interior Exterior Parts Wednesday at 9:22 AM
TTSaleen
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
