Progressive springs will work your shocks more than a linear spring will. By that, if your springs are progressive the rate gets higher as it compresses, therefore the shock has to work harder to keep the spring from bouncing more. The advantage of progressive springs are of course a better ride when not being pushed but will be stiffer when put through the loads of force from cornering. Progressive springs will also help to eliminate the bottoming out the spring when it is compressed to the maximum extents of travel.
A top grade shock/strut with a wide range of compression and rebound control for the different rates that are encured from a progressive spring going through its travel will be required if that type spring is used.
The advantage of linear springs is more constant spring rates while cornering and the effects of the shocks acting with it are more equal during the changing of forces applied to the springs.
For me, I have found that a linear spring is more predictable and has somewhat better (more constant) feedback while pushing your car to the limits during cornering.
I could not find a linear spring front and rear combo for my Mach1 that had the spring rates I wanted. I have the linear up front and the progressive with a very small difference in rate change on the rear. I have found that when at full tilt in a corner the rear will give me a slight pogo effect even with my shocks set on the full hard setting when I encounter a dip in the road surface.
