Projector Headlight Problem
chargedpony
53
I just put a set of projector headlights in my car this past weekend and now i am having a problem with the lenses fogging up only on one side.The vents are clear.What can I do to prevent this from happening?Should I seal off the vents on the headlights or leave it alone? Also I have to drive with my high beams on to have regular diving lights.And turn off the high beams to have brights.Does anyone have any clues on why this maybe happening.But the lenses fogging up is really bothering me.....Please help
Thanks
according to 5.0 Resto, these headlights require modification to the headlight panel, so i imagine your problem might be why... Did they come with any instructions? If not, maybe give 50 Resto a call and see what they say, or wherever you bought them, good luck, let me know how they turn out! I was considering them for my mustang!
headlights
I bought them off ebay so there might be part of the problem there but other than that they a good headlight.Thanks for the help guys.Ill try calling 50 resto.See if they can help me with the problems.Thanks to all of you...
I had exactly the same problem with mine so I took them off and took the rubber seal off and resealed them with some sealer I forget what it was called it was like a year and a half ago, put rubber seals back on before it dried and its fine now. I also have the same with the backward higbeams/lowbeams, I gotta figure that out yet to.
