  • SN95 4.6L Mustang Tech
Proper Caster & Camber
  • Thread starter Thread starter Dr Jay
  • Start date Start date May 28, 2008
  • 3
First Prev 2 of 3 Next Last
steve_stang2003
195
#21
  • Jun 2, 2008
  • #21
I'd just like to say that this is really a great thread!
Very informative!
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 2, 2008
#22
  • Jun 2, 2008
  • #22
R.J. said:
SaleenGT2001: Does a total toe spec of .32, mean that each side should be exactly .16 each?
Thanks
yes, there is some room for error though. anywhere between 0.10 and 0.20 will be ok
R.J.
813
Warwick, Rhode Island
Jun 3, 2008
#23
  • Jun 3, 2008
  • #23
SaleenGT2001: Here are the numbers form my last alignment. What problems could an alignment like this cause? Thanks
LF
caster 3.28
camber -1.03
toe .09
RF
caster 4.13
camber -1.13
toe .07
Total toe .16
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jun 3, 2008
#24
  • Jun 3, 2008
  • #24
I just wanted to add to the pool with my .02 experience. I have a similar setup as the OP. MM CC plates, Bilsteins, and Eibach Pros. I used the MM CC guideline for alignment and it did 2 things.
1.) Drastically improved the handeling of my ride around corners.
2.) Wore down the outer edges of my tires in record time.
As for alignment issues, I had mine done by a reputable, local tire center. They had no problem getting it into alignment. But because of the drastic tire wear from an agressive alignment (per MM guidelines) I had them re-adjust it closer to factory spec.
navarro98gt
213
chicago, IL
Jun 4, 2008
#25
  • Jun 4, 2008
  • #25
What are the proper factory specs?
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jun 4, 2008
#26
  • Jun 4, 2008
  • #26
I don't have that info. but apparently Ford has a specified range for proper alignment.
navarro98gt
213
chicago, IL
Jun 4, 2008
#27
  • Jun 4, 2008
  • #27
I just went to MM website and they have a section with a bunch of installation instructions. If you check out the instructions for there CC plates they specify Fords original specs and MM recommended specs for alignment. Good stuff.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 4, 2008
#28
  • Jun 4, 2008
  • #28
LF
caster 3.28
camber -1.03
toe .09
RF
caster 4.13
camber -1.13
toe .07
Total toe .16
it will have some noticable inner edge wear issues. other than that is is ok.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 4, 2008
#29
  • Jun 4, 2008
  • #29
the MM specs are WAY better than the ford specs. the -0.5 camber is just fine for normal driving and will not cuause inner edge wear. i would like to see your printout from that alignment. i would be willing to bet that there was too much negative camber.
MM alignment specs are NOT aggressive. the factory specs are more aggressive than the MM ones
R.J.
813
Jun 4, 2008
#30
  • Jun 4, 2008
  • #30
Wow you hit the nail on the head! My front tires are feathering (wearing unevenly) on the inner edges. What should I do to be sure I get rid of the tire wear when I get it realigned? Get the camber closer to -.5 and the toe closer to .16 each? Thanks
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Jun 4, 2008
#31
  • Jun 4, 2008
  • #31
get the camber as close to -0.5 as possible and set the total toe to 0.32.
you will see much better wear with this setup. also you should rotate your tires every 5K if you can. if they are a staggered size and directional you can flip them on the rims and that will keep them wearing a little longer
Jinx
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Jun 5, 2008
#32
  • Jun 5, 2008
  • #32
Sorry, but I can't find the print out for the alignment (I know I kept it for future reference), but it's lost. All I know is that the MM spec caused edge wear on my tires. I don't dispute the fact that the MM spec is far better than Ford's. When I had it re-done after buying new tires I requested a happy medium between the two.
R.J.
813
Mar 2, 2009
#33
  • Mar 2, 2009
  • #33
PM sent to SaleenGT2001
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 2, 2009
#34
  • Mar 2, 2009
  • #34
PM replied, sorry for the delay
R.J.
813
Mar 2, 2009
#35
  • Mar 2, 2009
  • #35
Thanks for your help
W
want2blile
#36
  • Mar 3, 2009
  • #36
anyone know of a good place to take my car in pasadena ,MD or glen burnie to get an alignment? I would do it myself but the company i work for will not allow anyone to work on there own vehicles I want to take it somehwere i wont get someone hot dogging my car and get all the spec. set right.
bwahl602
30
#37
  • Mar 3, 2009
  • #37
you can do thrust angle alignments... if you have adjustable LCA's... IE: adjustable length not perch height..
Im gonna build some UPR style LCA's... Adjustable length... so ill be doing thrust angle adjustments to make the rear axle square with the car... I guarantee you its not straight
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 4, 2009
#38
  • Mar 4, 2009
  • #38
it should be VERY close from the factory unless you have been in a wreck. i've not seen may solid axle cars with thrust issues unless they had been in some NASTY wreck
R.J.
813
Mar 9, 2009
#39
  • Mar 9, 2009
  • #39
SaleenGT2001: What do you think of my new specs?
LF
caster 4.07
camber -.55
toe .17
RF
caster 4.37
camber -.48
toe .15
Total toe .32
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 9, 2009
#40
  • Mar 9, 2009
  • #40
specs look good
you shouldnt have any wear issues with that!
  • 3
D
Brake & Suspension Rebuild
  • DuluthFoxbody
  • Monday at 4:00 PM
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:10 AM
DuluthFoxbody
D
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Still need an Alignment?
  • from6to8
  • Jun 1, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Jun 2, 2025
AeroCoupe
A definitive answer to the question of how much height Energy Suspension isolators add
  • 2000xp8
  • May 20, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2025
2000xp8
