What's the proper tool for pulling the power steering pulley? While pulling the engine out of the TurboCoupe last weekend I used a three-jaw puller to remove the power steering pulley and it bent the hell out of the pulley. I didn't really care at the time because I knew i wouldn;t need it. Obviously, I don't want to ruin the one on the Mustang when i pull it because I'll be re-using it on the Turbo motor. The Haines manual mentioned a special tool is required. So what is it, how much, and where can I get it?? Also, what tool is used to disconnect the A/C lines? I want to sell the compressor from the TurboCoupe, but can't disconnect the lines.
On a side note, the swap is progressing nicely.
The 2.3Turbo was pulled and is in the garage waiting to be cleaned up and new seals/gaskets installed. I decided to just ditch the A4LD for a T5 rather than running the A4ld for a while due to the state I found the A4LD in when I pulled it.
Thanks,
WES
The 2.3Turbo was pulled and is in the garage waiting to be cleaned up and new seals/gaskets installed. I decided to just ditch the A4LD for a T5 rather than running the A4ld for a while due to the state I found the A4LD in when I pulled it.Thanks,
WES
