Puffing exhaust?
Desert Stallion
651
Queen Creek, AZ
I have a DOHC 4.6L that's developed almost a 'lope' in the idle that is transmitted through the whole car when the motor's running as a harsh vibration. It's very regular, almost like a lopey cam would be, but this is a stock motor with stock cams, and there is no 'lope' to them.
This all started the other day when driving home. It was fine for a while, then while cruising at a constant speed on the freeway all of a sudden the car picked up a rough vibration. I thought I had chucked a wheel weight or something of the like and pulled off to check things out, only to discover that it's the motor that's vibrating.
When I got home I pulled plugs and wires and found a what appeared to be a bad wire, figured that was causing a miss and replaced it, but tonight I fired it up for the first time after replacing the wire to test drive it and it's little if not at all better. The same harsh regular lope-like vibration exists.
Any ideas? The RPM's are stable too. Could a cam have skipped a tooth or something and changed the physical valve timing in one of the heads? The motor's only got 114k miles, so I figure it should just now be getting broken in. It does have that gratuitous tensioner tapping on first-start in the morning, but it goes away after a second of running, and the car has to sit overnight or longer for the tensioners to bleed down again. Also, I had the driver's side valve cover off a month ago to change the cover gasket, and the chain wasn't loose or anything unusual.
Yep, ohm checked the wires, put them back where they're supposed to be, plugs look good, coils were all sparking when I pulled the wires one by one looking for a bad cylinder...
I'm gonna run a compression test in a few minutes and see what that turns up. After that I'll pull injectors and see about having them tested, and after that... Not sure yet.
Compression test didn't turn up anything unusual. Lowest cylinder was 180, highest was 190, so that's about a 5% difference between the lowest and highest cylinders, not too shabby for 114k miles on the motor.
Went and cleaned and greased the plug wires again and reassembled, no change in the problem still. :bang:
So, I guess this leaves only ignition module or a coil pack huh? Is there a way to test the coil packs?
