puked all my coolant
  • Thread starter Thread starter 2006KJ
  • Start date Start date Jun 3, 2010
2006KJ
128
North West PA
Jun 3, 2010
  • Jun 3, 2010
well.. it happened. the nipple on the back of the intake manifold that goes to the heater core broke today... and then pumped out all my coolant everywhere including the windshield, fenders, hood, and a small lake on the road for 30 feet or so. so today i ordered...
- PI intake manifold from american muscle
- Upper and Lower intake gaskets (do i need both or just lower?)
- 0-rings for the fuel injectors (8)
- Will order a new water pump soon as i get it off to see the width (2 available.. one is 60some mm from the pully end to block the other is 87mm)
- Water pump nipple
- Heater hose that goes in the valley of the block from the water pump back
my car is an early built car in 2001 (i have the T45 tranny).. do i need anything else (besides coolant)? Also any tricks to installing this? i keep seeing something about the altinater bracket? any advice is appreciated!
Shiroelex
There's nothing worse than aut
728
Westland, MI
Jun 3, 2010
  • Jun 3, 2010
You shouldn't have to worry about the alternator bracket. That's if you are swapping from NPI to PI. Also, there technically isn't an upper intake gasket. Most intakes have an integrated rubber seal where the plenum mounts. I believe the Dorman intake uses that same gasket style on the lower mounts as well.
RedDaemon
3,470
9
108
Atlanta, GA
Jun 4, 2010
  • Jun 4, 2010
- Water pump nipple
i dont think i have ever read a case of this manifold breaking in this spot before. were you working in that area prior to the break?
Read this:
99-01 PI to PI Intake Manifold Swap Writeup - Mustang Forums at StangNet
kuwait
194
Jun 4, 2010
  • Jun 4, 2010
Read this:
its quiet common , i seen it 3-4 times at least , also i haven't seen a car that didn't break its plastic intake eventually , mine is a 2004 and mine broke at the thermostat housing and yes it had alum cross overs , maybe its the hot weather here but those plastic intakes are just asking for trouble.
RedDaemon
3,470
9
108
Atlanta, GA
Jun 4, 2010
  • Jun 4, 2010
thats so disheartening.
patman0911
2,287
Tuscaloosa, AL
Jun 4, 2010
  • Jun 4, 2010
You don't need the nipple or valley hose - That's only of you're replacing an NPI intake with a PI.
You probably will need the alternator bracket. The bracket mounting locations for plastic crossovers and aluminum crossovers are different. You may be able to modify yours but I'm not positive about that - the plastic crossover PI intake has much different mounting locations than either of the NPI intakes or the aluminum crossover PI intake.
If you're getting gaskets, you might as well get the lowers and the upper too.
RedDaemon
3,470
9
108
Atlanta, GA
Jun 4, 2010
  • Jun 4, 2010
for his particular situation, he can modify the alternator bracket he already has, theres a pic of it in that writeup i linked to above
patman0911
2,287
Tuscaloosa, AL
Jun 4, 2010
  • Jun 4, 2010
Ah, yep, looks like modifying the old bracket will be fine.
Excellent writeup, BTW - love the color highlighted photos and arrows pointing stuff out
2006KJ
128
North West PA
Jun 4, 2010
  • Jun 4, 2010
yes EXTREMELY good write up... i dont think it could possibly be any better. and thanks for all the other input too... i already ordered the valley pipe so i might as well keep it... with 109000 miles mine could probably used replaced anyway. anymore advice is appreciated! this site has great people and a wealth of knowledge for sure!
J
jlds91389
241
Orange Tx
Jun 6, 2010
#10
  • Jun 6, 2010
  • #10
mine broke in the same place lol. i have the dorman intake it didnt require any gaskets. mine also cam with three brakets to choose from. i had to use a diffrent one than stock.
RedDaemon
3,470
9
108
Atlanta, GA
Jun 7, 2010
#11
  • Jun 7, 2010
  • #11
thank you both and good luck with the install
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
J
Intake replace help
  • jshyuw7
  • Jun 19, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jun 19, 2025
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
D
Engine Where is this coolant leak coming from?
  • dqureshi06
  • Sep 2, 2024
2K
Fox 5.0 Mustang Tech Sep 7, 2024
Praetorious
P
