Pulled Codes, how do I fix this?
  • Thread starter Thread starter 281pony
  • Start date Start date Sep 10, 2004
281pony
2,681
Oly, WA
Sep 10, 2004
  • Sep 10, 2004
ok i pulled my codes in the first 2 stages.
i got a few. 23, 81, 82, and 95.
23 is the tps, no suprise there.
81 and 82 is says: air diverter solenoid fault, intake air control circuit fault/ air injector diverter. so basically my air diverter? what the hell is that, probably something simple.
95: fuel pump secondary circuit fault. how do i get to that?
any help is appreciated.
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
Sep 10, 2004
  • Sep 10, 2004
man i gotta get one of those electronic things you pull codes with those are cool, where did you get yours and how much?
281pony
2,681
Oly, WA
Sep 10, 2004
  • Sep 10, 2004
yeah its pretty cool. 32 dollars at walmart.
i saw that 81 and 82, in detail by jricher are the smog pump. my smog was disconnected by the previous owner, am i going to need it hooked back up?
still un-sure on the fuel pump relay part.
thanks for any advice
281pony
2,681
Oly, WA
Sep 10, 2004
  • Sep 10, 2004
nobody?
The Shape
2,224
East ARKANSAS Delta
Sep 10, 2004
  • Sep 10, 2004
The 81 and 82 are because you removed your smog pump they won't hurt driveability at all.
DMAN302
My mom says thanks for the pearl necklace.
Nov 8, 2003
2,120
windsor, Canada
Sep 10, 2004
  • Sep 10, 2004
Reset the TPS to to .80-.95
I think you may have a fuel pump going out on you, or possible the regulator, use the walmart code reader to run a cylinder cycle test it will test each cylinder.
DMAN302
Nov 8, 2003
2,120
windsor, Canada
Sep 10, 2004
  • Sep 10, 2004
Unfortunately you need to approach it with a list and cross them off as you check..painful sometimes but luckily you will oftem stumble across other things in need of repair while trying to solve your original problem. Eventually you will solve the problem so just keep at it.
281pony
2,681
Oly, WA
Sep 10, 2004
  • Sep 10, 2004
i did the other tests now and it seems fine, except for the code 95.
fuel pump secondary circuit fault, whatever that is. think it is the regulator? ill change the tps later tonight, dont have anyway to read the volts here. fuel pump issue makes sense though somewhat, no power, surging/bumping at a consistant speed.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 11, 2004
  • Sep 11, 2004
Code 95 - the 95 code is because at one time or another the fuel pump relay circuit hiccupped and didn't provide power the pump when the computer told it to run. Sometimes this is a one time thing, other times it is a no run or runs poorly condition. If you are having problems, follow the test path.
To help troubleshoot the 95 code, follow this link for a wiring diagram http://www.autozone.com/images/cds/gif/large/0900823d80167162.gif
Using the diagram, check the red/black wire from the fuel pump relay: you should see 12 volts or so. If not, check the inertia switch: on a hatch it is on the drivers side by the taillight. Look for a black rubber plug that pops out: if you don't find it, then loosen up the plastic trim. Check for voltage on both sides of the switch. If there is voltage on both sides, then check the Pink/black wire on the fuel pump relay: it is the power feed to the fuel pump. No voltage there, check the Orange/lt blue wire, it is the power feed to the fuel pump relay & has a fuse link in it. Good voltage there & at the Pink/black wire, swap the relay.
C
Engine Code 94 and 13
  • CmdrDerp
  • Nov 3, 2024
Fox 5.0 Mustang Tech Nov 4, 2024
AeroCoupe
Engine Throwing codes 94, 33, 34, 44, and sporadic engine shutoff.
  • Ryu
  • Oct 9, 2024
Fox 5.0 Mustang Tech Sep 13, 2026
M
Progress Thread 1993 Ford Mustang 5.0 convertible stock manual - ODB Codes shows running lean
  • mcalvo
  • Feb 11, 2025
2K
Fox 5.0 Mustang Tech Feb 22, 2025
AeroCoupe
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
A9L on 94 engine, no priming injector pulse?
  • Wallyman
  • Jun 17, 2024
  • Other Auto Tech
2K
Other Auto Tech Jun 24, 2024
Wallyman
