pulled codes need info
Code 34- PFE or EVP circuit above the closed limit of 0.67 volts.
Code 96- Fuel pump secondary circuit failure. The EEC did not sense battery voltage on the Fuel Pump Monitor circuit.
What sort of problems are you having??
Ok cont mem code 34. Ck evp resistance while applying vacuum to egr valve. Note the evp circuit indicated that the egr valve was open with the engine at stabilized operating temp and at idle..than cont mem code 96 fuel pump circuit was code 87 also present if no check eec iv harsness .code 96 without 87 indicates that during vech operation ,one of the following occurred,open in the vbatt circuit between batt+ and the fuel pump relay,fuel pump relay contacts opened,open in the power to pump circuit from the fpr to the fpm splice. Want more?
Is or Was check engine lite on . If work was done before your purchase they might be false now .as to restarting every ford ive owned did that .what is cca of battery . I allway put 1000 cca in the older cars ive had
