I checked for the codes because after about 5 minutes of driving I get t check engine light. It runs fine and strong but the light comes on. The air pump and egr are deleted with the special kit for the EGR. So here are the codes I pulled.
On Demand codes --Code 15 PCM ROM test failure- failure is internal to PCM. (c) PCM KAM (Keep Alive RAM Memory) failure.
code 81 TAD or AM-2 (Thermactor Air Diverter)/ Secondary Air Injection Bypass (AIRB) solenoid circuit failure, or SCVNT (Speed Control Vent) circuit failure (IVSC test). 81 (o): 2.3 Turbo. Boost control circuit failure.
Continuous codes -- code 33 Insufficient EGR flow detected.
code 41EGO/HO2S oxygen sensor voltage always below "lean" on bank #1. (c*): No EGO sensor rich/lean transitions detected, bank #1
code 87 FP relay circuit failure- suspect inertia switch, fusible link, FP relay.
code 91 EGO/HO2S oxygen sensor voltage always lean, bank #2. Suspect vacuum leaks, EGR system, plugs, plug wires, EGO sensor. (c*): No oxygen sensor transitions detected, bank #2.
What do I do to fix them. i know replace the 02 sensor probly fix two of them but what about the others?
please help.
please help.
