Pulley Question
RTRMustangGT
43
Why is it that most people say that when you install underdrive pulleys it is also a good idea to install a timing adjuster or a programmer to adjust the timing. What is the idea behind this? Do the pulleys cause detonation? :shrug:
so it is not neccesary to get a timing adjuster when you install pulleys. i am planning on getting a set from steeda soon and i was just wondering. i didn't think that you would need the adjuster but i wasen't positive. how much more power can you get if you do add the adjuster with the pulleys. i have heard that you can get around 8-10 with the pulleys but how much will the timing adjuster give you?
